scorpio_vette
- Milwaukee Wisconsin
95XJ, 4.0L AW4, NP231, chry8.25(welded)/D30, 3" lift, 31's.
so yesterday i was at a snow run, and took my little cherokee through course that i probably had no business being in. it was one of the more difficult courses i've ever been around with rocks the size of my tires and bigger and 2 feet of snow. well after i finally made it out of that course my tranny was acting real weird.
in 2wd, it wouldn't move. in 4hi it wouldn't move. in 4low it would drive. in 2wd and 4hi, the engine would just rev and rev but it wouldn't move.
so i got it back down to the parking lot and started looking it over. the shift linkage was fine and going through all the t-case gears. then suddenly i noticed that if i was in 2wd or 4hi, it would start to roll if i reved it up to about 2,000rpm. so i started checking all the fluids and everything, and they were all full.........BUT.....the tranny fluid was FUBARED. i haven't seen tranny fluid that burned in a long time. so i let it sit and cool down for about 1 hour and then decided to try and drive it home. about 10 minutes after jumped on the highway, the tranny started seriously improving.
so here's my question............is it actually possible to overheat the transmission to where it almost quits working, but when it cools down it works fine again???
on the way home (2hour drive), i stoped at the in-laws and stayed there for about 3 hours, and then finished the drive. when i started up the cherokee and took off, it was acting completely normal again.
i'm gonna try to disconnect both lines on the tranny, and stick the output in a 5gallon bucket, and the input line in a 5gallon bucket with fresh tranny fluid, and try to run a few gallons of fresh fluid through the tranny and get it flushed really good.
PS: does anybody have any recommendations for a good quality tranny temp gauge, and additional cooling, or will any trans temp gauge from the parts store be sufficient???
