Old July 9th, 2005, 13:50
Purple's Avatar
Purple Purple is offline
Fan override switch 97+ models
does anyone know how to make one? I know XJ-Armor sells it, but that guy is a jackass and i do not want to deal with him. Heard too many bad words about him. Anyway, i need to know where to splice the wires, etc... Thanks.
Old July 9th, 2005, 15:46
stesul411's Avatar
stesul411 stesul411 is offline
Re: Fan override switch 97+ models
try here.
http://www.olypen.com/craigh/tech.htm
Old July 9th, 2005, 17:26
Purple's Avatar
yeahh, i found that on google it will not work wirh 97+ models, Thanks Anyway
Old July 11th, 2005, 12:36
DaffyXJ's Avatar
DaffyXJ DaffyXJ is offline
NAXJA Member #929
Fan Over ride switch, as in turning on the fan before the temp sensor does?
IF that's the case just wire in a switch and relay. Mind the current draw on the fan. (Use 10 gauge wire on the primary side of the relay)
I wired a toggle in to bring the fan up for the tranny cooler if needed before the temp sensor turned on the fan. Since I by passed the radiator and installed a bit of overkill on the tranny cooler, I haven't needed it, tranny stays cool all day long. But it (the switch) works.
01 XJ.
Old July 11th, 2005, 16:54
Purple's Avatar
i understand, but what about the connection for the fan, the stock one, how do i wire in the switch and relay, so when i flip the switch to "on" the stock connection will get "disconnected" so no power goes to the stock control box/computer ...?
Old July 11th, 2005, 17:45
baldwinwb baldwinwb is offline
I just turn on the AC to the lowest level, keeps the fan on. This way both you and the engine get cooler.
Old July 12th, 2005, 21:32
Purple's Avatar
lets say, its ....+15 C. and i dont want to run ac... just the fan...
Old July 12th, 2005, 21:49
Timber's Avatar
Timber Timber is offline
In '97+ models, the aux. fan is negative switched. The general consensus seems to be to leave it alone, due to the ECU being involved. It, the ECU, would need to be isolated by relay or, I suppose the better way might be that a diode could be used to prevent current from getting to the ECU. I'm still looking for an acceptable way to do this, too.
Old July 12th, 2005, 22:06
Purple's Avatar
i will ask my friend HAM to solve this for me, what if the fan is operated manualy , and ECU Neg voltage kicks in? what will ECU get? will it get some kind of code that the fan does not respond or something?
maybe an additional fan would be the resolution? i have looked at the space between the grill and my ac/radiator cores, there is about ... hmm..2 inches?
I dont understand how somebody on ebay can be selling something like that, and there is no diagram on how to come up it.
Old July 12th, 2005, 22:22
goodburbon's Avatar
goodburbon goodburbon is offline
I did away with my factory fan, put in 2 electrics and wired them up to a double pole relay. one pole for each fans positive. I am using a thermostatic switch, and the original fan power wire to power the relay coil. no adverse effects, but I am only using the positive side of the fan circuit, and it is grounded straight to the battery.
Old July 13th, 2005, 07:07
Timber's Avatar
I'm not sure how XJ Armor can claim it will work for '84-'01s because the circuits are different. I would think using it in a '97+ would trip the ECU and check engine light. Not sure, though; I know just enough about electronics and schematics to get myself into a good amount of trouble.
Old July 13th, 2005, 13:34
jxj's Avatar
jxj jxj is offline
NAXJA Member # 1559
I used the wiring harness that I bought used from a set of Piaa offroad lights (rated at 100W)-relay, switch. Connected the switch to relay, power from fuse box and splice the wires to the aux. fan (above the plastic connections). Works everytime I turn on the switch. No codes, no check engine light, no other problems that I can tell. Over 2 years now. I'm no expert at wiring stuff up-just letting you know what I did.
Old July 13th, 2005, 14:06
Timber's Avatar
jxj--what year is yours?
Old July 13th, 2005, 14:17
jxj's Avatar
jxj jxj is offline
NAXJA Member # 1559
Thumbs up Re: Fan override switch 97+ models
Sorry,
2001 AW-4 Limited 5.5RE ARB Front & Rear Teraflex HP60 CRD Rear, Teraflex HP44 CRD crossover steering, Atlas II 3.8.
Old July 13th, 2005, 14:23
I think the defroster turns the aux fan on as well. It's hot as nuts here, I never use it.
Radiator Conversion / How to Switch Fan? Runnin'OnEmpty Modified Tech Discussion 7 May 5th, 2008 08:34
fan switch on open radiator conversion flag2442 OEM Tech Discussion 9 June 14th, 2005 13:20
MASSIVE elec. problem after aux. fan switch install! Fergie Modified Tech Discussion 35 June 14th, 2005 05:00
Ignition Switch Removal BIGSLVRXJ OEM Tech Discussion 3 August 15th, 2004 22:18
Please help me with this aux fan switch before I light my POS Jeep on fire. Pics! 90Pioneer Modified Tech Discussion 12 May 15th, 2004 21:53
