Old May 11th, 2005, 14:33
shayzj shayzj is offline
Wink D44 front inner axle seal dilemma
I have the YK D44 yukon master install kit and the supplied inner seals are too small to press fit into the Waggy 44 axle tubes. I have been all over and none of the local part stores have a clue to say the least.
So I call Randy's R&P and they give me a bullshit # that ended up being a seal for the hub end. Can anyone shed any light on the problem.
I take it this seal is for a TJ 44 which has a smaller dia. tube.
Help so I can go ahead and **** up this gear install
Shay
Old May 11th, 2005, 15:06
Re: D44 front inner axle seal dilemma
Oh yeah it is an 81 model axle.
Shay
Old May 11th, 2005, 15:40
sintax's Avatar
sintax sintax is offline
have you tried talking to your local stealership?
Old May 11th, 2005, 15:44
red91's Avatar
red91 red91 is offline
Shay
Yeah. Call them back. Go over the WHOLE thing again. I've gotten a fair amount of stuff from them, and they are smart and knowledgable about what they do.
Noobie question about Axle Seals in d30 Front (Leak?) wescam Modified Tech Discussion 13 September 8th, 2009 07:39
Rear Axle Seal Leak Jerms OEM Tech Discussion 1 January 7th, 2005 22:40
Front axle U-joints, Need replacing BskisXJ OEM Tech Discussion 9 September 15th, 2004 13:55
Need some Front Axle Help MrShoeBoy Modified Tech Discussion 0 September 5th, 2004 16:18
D44 front; long thread xjrugger Modified Tech Discussion 27 June 3rd, 2004 08:31
