Hmm. I run (as many in the UK do) my XJ on LPG, which I take to be the same as propane. I notice very little difference in performance, and a lot of difference in my wallet, since LPG's half the price of gasoline.
The general blurb on that site is somewhat misleading in places:
1 The octane rating is high at 100, but the calorific values are lower, so you do lose a little power compared to gasoline (5-10%, depending on the system installed).
2 Of course the propane system is sealed (it has to be because the bl00dy stuff's a gas unless pressurised, right?!), but that won't mean that you won't ever flood your engine. How many water crossings to normal XJs do without getting into trouble? I wouldn't take that stuff too much to heart.
But enough pedantry...
The good side of LPG/ propane is that it's cheap, clean and cheap! Jeeps do convert easily to it, and both multi-point and single point injection systems are used with success. You'd get as many opinions on which is best as with which suspension lift is best, so you'll have to do your own homework on that one, I'm afraid.
Personally, I won't run anything as thirsty as a jeep on anything else - gasoline over here costs $6.50 a gallon, or thereabouts, with LPG costing half that, so the conversion pays for itself within a year or so, under normal driving conditions.
Tanks for them either go in the trunk (like mine), or under the body, with a little 30 litre gas tank there too. If you opt for that route, you lose about 3" clearance, but for a DD, who cares? If you choose the tank in the back, you have to have the dog on the back seat, so it's really swings and roundabouts.
