CRAIG-XJ
- harwinton, ct
I have a 2000 XJ with a Selec-trac. It seems to go into 4wd in full time but doesn't always go into 4wd in part time. Does anyone have any sugestions or similar problem?
CRAIG-XJ said:I don't have FSM. The Tech at the dealer thinks its a bad transfer case. He can't explain the problem. I don't believe it wouldn't it be more likely for full time not to work than part time. Can anyone suggest a method to test it prior to me replacing it with one from a boneyard?
CRAIG-XJ said:I have a 2000 XJ with a Selec-trac. It seems to go into 4wd in full time but doesn't always go into 4wd in part time. Does anyone have any sugestions or similar problem?
CRAIG-XJ said:It lever is not the problem It moves to all positions just fine the problem is the front wheels don't lock in always. The T-case isn't making any strange noises but I went to pull it into 4wd on an icy trail and it didn't engage even when i stoped and locked it in.
CRAIG-XJ said:No is was at night.
CRAIG-XJ said:We're Having A Blizzard Here In Connecticut 4wd Seem To Be Working Fine. Maybe It Was Just The Driveshafts Wern't Spinning At The Same Speed. Have You Ever Heard Of A Tcase Having An Intermittent Problem Or Is The Tech At The Dealership Just Trying To Make Money.
