Bronco
- Swansboro, CA
I’m going to be putting in a new Master Cylinder. Is there anything to it, or do you just unhook the old one and hook up the new one and bleed? Any tips would be appreciated. Thanks in advance.atriot:
The biggest problem with this approach is that you are recycling dirty, contaminated, old brake fluid back to the MC when you do this. That's not a good practice for long healthy brake system life.Bronco said:Just thinking nutty here. Bear with me. Could you run some tube from each of the 4 wheel bleed screws back to the MC and just pump the brakes till they clear all the air? It would be a lot of tube but seems like it would really let you go to town bleeding it. I’m putting it in tonight and I don’t have that much tube so I’ll let you know how it goes. Thanks for all the help.
