Old October 24th, 2017, 21:31
XJ_NorCal XJ_NorCal is offline
Question 98 XJ build help - Armor & Lift...
I recently bought a 1998 Cherokee Sport that is bone stock with ~ 113K miles. Aside from admiring nice rigs from a distance and reading random threads I am new to the XJ scene. In the next 2 weeks Ill be draining and replacing all fluids. I also need to develop a game plan for which brands I should look at for the modifications I want to do and in which order I should do them to fit my needs and my budget. This is the main objective of this thread. Im hoping I can get some help from the XJ community.
My goal is to build something capable of going off road for camping trips and some moderate to easy rock climbing and off road trails. Im not trying to build a full on rock climbing rig. I've listed some trails in my area for reference below. This jeep is not my daily driver but I do plan on cruising it around town after work. I never plan to run anything larger than 33 tires and would be just fine maxing out at 32 tires.
Currently, my plan is to prioritize getting it trail ready by adding armor (TC skid, gas tank skid, rock rails, and Rear Diff armor), new tires and a lift in that order. I had a $1500 budget to get this done but I scored 31 tires and wheels, a TC skid plate and RC lower control arms and brackets (I may or may not use these) for $300 so Im down to $1,200 for the rest. Which parts should I invest most of my budget in and where can I save money?....I anticipate having another $500ish dollars added to the budget at the end of January (tax return!!) for what its worth.
Also, I am comfortable doing most mechanical and bolt on stuff but no welding. I'm new to this so all feedback is greatly appreciated.
Trails in my area:
Frank Raines OHV
Hollister
Carnegie
Slick Rock
Lake Tahoe
Old October 25th, 2017, 20:37
Re: 98 XJ build help - Armor & Lift...
I figured this information would be helpful as well....
1998 Jeep Cherokee Sport
113K miles
I6 4.0 litre
Automatic Transmission
NP231 Transfer Case
Old October 25th, 2017, 21:21
Goose_XJ88's Avatar
Goose_XJ88 Goose_XJ88 is offline
I'd recommend front and rear diff armor, sliders, and a gas tank skid like you have planned. Plan on spending some if not all of your cash on black Friday and cyber Monday as a good amount of companies will have sales going on.
I always try and buy as much as I can from one retailer to save on shipping or at least factor that into the price of the items you're buying and where you buy from.
Before you lift the rig, take it out to Hollister stock but with armor and get familiar with what it is capable of. It will do a lot more than you think.
Front tow points are also a good idea and the Boostedworks ultimate steering brace stiffens the chassis while also providing tabs for shackles to hang off of.
Check out the Sierra Chapter for sale, lots of good stuff just posted.
88 XJ Laredo 8" RE SA, drop brackets, 35s D30/44 4.56, AW4, 242, 7100s, Logans ft winch bumper, JCR swing out tire carrier, JCR sliders, 96 booster, 97+ mirrors & console (FOR SALE)
99 XJ Limited, AW4, 242, Colombia Edition WJ Seats, Stock. Future 4.5" lift, TnT LA, 33s armor, 231 SYE, D30/44 4.56, rear locker, etc
93 XJ 2 Door AX-15 D30/8.25 3.55 swap, (FOR SALE)
92 MJ AW4 2wd, 97 mirrors. Future 4wd swap, 242, MJ 44, Eliminator Roll bar, Bucket seats, 97+ console
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
This should give you an idea
700ish for a 4" zone lift
200 for an sye
50 to 70 for a front driveshaft for the rear
spend the rest front, rear, axle shaft u joints and supplies to install the sye and tow points
Old October 29th, 2017, 23:53
TC Skid, Front and Rear diff. armor secured!
I'll be hitting the junkyards for a ZJ gas tank skid and an exhaust manifold next weekend.
I've settled on Affordable Offroad Rock Rails that I'll get on Black Friday.
I really need some advice for my lift. I've looked long and hard at lifts from Rubicon Express (3.5" & 4.5"), Zone (4.5"), Iron Rock Offroad (4") and Rough Country (4.5"). Full Leaf packs, quick discos and adjustable trackbars put all these lifts over $1k except the rough country lift. Ruled out RE's 4.5" and IRO. I'll be running 31" tires for at least the next year and will max out at 33" tires, maybe even 32".
RE's 3.5" Super Flex kit comes out to about $1,324 but doesn't include upper control arms, TC drop or drop pitman arm.
Zone's 4.5" lift comes in at $1,101 but doesn't include upper control arms or drop pitman arm.
Rough Country's 4.5" comes in at $950 and has everything...but it's a rough country kit. It's hard to look past that price point though, hell for $1,180 I could get this kit with Billstein 5100's.
Any thoughts considering the trails I plan on frequenting and the tire sizes I'll be running?
Old October 31st, 2017, 12:16
I replied to this a couple days ago. Who's the moderator?
Old November 4th, 2017, 19:33
bump
Old November 6th, 2017, 13:01
sinat01's Avatar
sinat01 sinat01 is offline
If you know someone that can weld, you can do 2x6 1/4" steel rock rails that replace your rocker panels for cheaper than bold on rocker armor. I run a IRO 3" lift with 1.5" lift pucks up front, their full leaf pack with boomerang shackles for a total of 4.5" of lift.
figure on getting an adjustable track bar (core4x4, IRO, ironman4x4fab)
Riddler diff covers are nice and don't break the bank too bad.
I have a 99 on above mentioned 4.5" lift with 33x10.50 KM2s on stock alloy wheels, it rubs at full lock, but I can remedy that. mine is a daily and a weekend warrior. biggest thing for a setup like mine is not cheaping out on important parts.
if you do a t-case drop instead of a SYE just find a crossmember off a 5 speed Cherokee, they give a 1" drop w/out losing ground clearance.
a H&T SYE works good, some people bash them but I have not had issues with mine what so ever. a piece of advice, any bolt you take out, either put anti-seize or locktite on it, youll appreciate it when you gotta take it apart again.
Old November 6th, 2017, 13:03
sinat01's Avatar
if this pic works, this is mine
Old November 6th, 2017, 14:26
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
It didn't so it's not.
Try THIS or more specifically THIS.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 D-44 Stock-ish
Old November 6th, 2017, 15:36
sinat01's Avatar
that works, Thank ya lol. when im at work its hard to put any pictures up cuz a lot of sites are blocked.
(btw I don't have any swaybars in that pic)
Old November 6th, 2017, 15:37
need-a-bow's Avatar
need-a-bow need-a-bow is offline
Just a thought, I found 2 separate RE3.5 leaf springs for $ 80 and $90 respectively on eBay that were scratched up but new. Add a new pair of 4.5 RE Coils from amazon adds another $90. Id get a shackle relocation bracket like HD Offroad($130) or IRONMAN4X4($130). Add Some RC discos($69), and a set of bilstien shocks($350). For under $ 900 you have a great lift. You can get a decent set of LCAs with Heim joints for $ 160 or so from several sponsors.
Old November 6th, 2017, 15:50
sinat01's Avatar
core 4x4 and ironman4x4 both have good control arms that don't break the bank.
either of those SRBs are good, the slider boxes are supposed to be good, my buddy has them, and loves them. doestech shocks are good for $190/4 too, not gonna ride quite as good as bilsteins, but are longer and well built
Old November 7th, 2017, 09:31
so many options....
Old November 7th, 2017, 11:26
NAXJA Member 4950
http://dpgoffroad.com/products/rubic...id-4-inch-kit/
Or when you an add your extra 500.
http://dpgoffroad.com/products/44-5-...mu-hybrid-kit/
quater panel armor: worth it? anyone make flare-friendly armor? jmg222 Modified Tech Discussion 20 March 2nd, 2016 22:50
2door upper 1/4 panel slider/armor build 831_xj Modified Tech Discussion 13 February 3rd, 2015 02:22
WTB armor and lift parts redneck Arizona For Sale/Wanted 1 June 26th, 2011 07:35
Little Bit of Armor Added and Bumper Build macs97XJ NorthWest Chapter 5 August 28th, 2008 13:35
BODY ARMOR Rear Quarter Panel armor??? 98XJROKS Modified Tech Discussion 30 February 21st, 2007 23:25
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
