Old August 28th, 2017, 14:26
Murray_XJ Murray_XJ is offline
Shock Recommendation
Hey guys - '98 2 Door sitting on a 6.5" Iron Rock lift. Needing to upgrade the shocks for ride quality and wanted to touch base here first for suggestions. The Jeep is probably 70% daily driver (hence needing a some ride improvement) and used modestly off-road to go to camp, logging roads, firewood... nothing crazy. Thanks for your thoughts guys!!
Old August 28th, 2017, 14:34
Kittrell's Avatar
Kittrell Kittrell is offline
Re: Shock Recommendation
Bilstein 5100's.
Old August 28th, 2017, 14:37
That was my first thought as well... I used those in a swap for a '92 that I had on a 4" lift and the improvement was worth while. I saw their shocks listed as topping out at 6" of lift so I wasn't too sure with the "6.5" lift.
Old August 28th, 2017, 14:57
Tbone289's Avatar
Tbone289 Tbone289 is offline
I would suggest the 5100s as well. However, I would also suggest that you measure for the shock length you need, rather than going with Bilstein's suggestion for the amount of lift.
Old August 28th, 2017, 16:09
sinat01's Avatar
sinat01 sinat01 is offline
Doestech is what I have, get them through IRO $180 a set. tad on the stiff side, but not bad, super beefy and well built.
Old August 28th, 2017, 18:39
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Bilstein 4600, DoetschTech DT-3000, or BDS.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old August 29th, 2017, 14:45
Thanks guys... I appreciate the thoughts.
Anyone have experience with the Fox 2.0s? Just covering all bases...
Old August 29th, 2017, 17:39
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Fox makes a good product, but they tend to be back ordered a lot.
For the same price range look at Bilstein 7100's too.
Old August 29th, 2017, 22:15
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
Iron rock makes a 6.5" kit in short arm and long arm....which is yours? If you are on short arms, drop brackets will do a lot for ride quality. If you are on long arms, disregard.
As for shocks, I have nothing but good to say about bilstein reservoirs
88 MJ on 40's. 98 XJ on 35's. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky, girls need bikes too. 2011 R6, girls need sport bikes too. 99 Toyota Avalon, daily. 97 Miata, girls apparently need miatas too.
And everything fits in the garage!
Originally Posted by mako my day View Post
Johnx is #1
Old August 29th, 2017, 23:44
clydefrog's Avatar
clydefrog clydefrog is offline
I'm gonna suggest the bilstien 5160's or 7100's.
Prob gonna have to do some measuring to see which is best for your lift. I find the Fox 2.0's to be a bit stiff and the 5100's are stiff as well. My DD is a bimmer so I like a pretty stiff ride but in the XJ I like it a bit softer. I have people complimenting the ride in mine with my 5160's. I didnt use the XJ 5160's though, I have ones designed for the TJ in the front and a pair designed for the front end of a JK in the rear (I liked the valving better). I would give you the P/N's but I only have 4.5" of lift. The 5100's have too much rebound compared to the 5160's.....
'87 with over 300k miles, and a CA legal LS swap.
Expedition built: http://www.naxja.org/forum/showthread.php?t=1129315
When you want to be someone you drive a lifted JK, when you already know who you are you drive an old XJ.
Old August 29th, 2017, 23:51
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
Fox 2.0s
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old September 5th, 2017, 12:49
Thanks again guys... I have the IRO long arm kit. Thanks for asking that, I should have specified. I am still looking around, a couple house projects came up over the long weekend. there are few things that take priority over the XJ, but the house tends to. haha.
Fox shock recommendation Kyle Modified Tech Discussion 8 September 7th, 2016 17:12
Shock Absorber Recommendation Needed RTicUL8 Colorado Chapter 10 March 30th, 2009 23:53
Shock recommendation? montanaman OEM Tech Discussion 10 December 10th, 2005 09:48
Another Shock Recommendation Thread...Sorry DharmaDog Modified Tech Discussion 9 August 19th, 2003 08:30
Shock recommendation crazy4mopar Modified Tech Discussion 2 May 5th, 2003 09:32
