Old July 10th, 2017, 09:22
PacificEd's Avatar
PacificEd PacificEd is offline
Regular Joe
10mm or 1/2"
I'm thinking about ordering the Iron Rock upper arm flex joint to ensure my front bushing stays put in the differential. It seems to float around some and someone recommended that I use this.
Here is the part: http://www.ironrockoffroad.com/10677.html
Now the question is it better to use the stock 10mm bolts or change over to the 1/2". I have good 10mm grade 12.9 bolts I'm using now but it sure would be easier to find 1/2" grade 8 bolts if I got into a pinch.
Is there any other advantages/disadvantages I overlooking to going with one over the other?
I won an IRO gift certificate and I thought this would be a good use for it.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Old July 10th, 2017, 09:46
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
Re: 10mm or 1/2"
Are you running radius arms?
As for the bolt I'd probably stick with the 10mm as that isn't a bolt that tends to walk away very often.
President & SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old July 10th, 2017, 09:49
PacificEd's Avatar
Regular Joe
Re: 10mm or 1/2"
I've got a 1988 Cherokee with short arms. The uppers and lowers are from Rubicon Express. The coils are Rough Country 4.5" lift and I have the 1.75" spacers. Everything sits pretty nice.
Old July 10th, 2017, 09:58
RCP Phx RCP Phx is offline
Re: 10mm or 1/2"
I wouldn't worry about the bolt size, I would work on getting drop brackets at that height!
Old July 10th, 2017, 10:17
GSequoia's Avatar
Re: 10mm or 1/2"
Okay, just wanted to make sure as radius arms are hard on UCA bushings by design.
Us normal people...
Old July 10th, 2017, 10:32
TRCM's Avatar
TRCM TRCM is offline
Re: 10mm or 1/2"
agreed.....
When I replaced my UCA arms & bushings, I went to the 1/2" bolt...
1) I didn't like the slop between the factory ones & the bushing sleeve
2) the factory flag was damaged, so I had to get new bolts anyway since I couldn't re-use the old ones
Old July 10th, 2017, 11:26
PacificEd's Avatar
Regular Joe
Re: 10mm or 1/2"
Sorry, I forgot to mention that. I have the Rough Country drop brackets. We chucked the crappy braces and my Father-In-Law fabricated some new ones very similar to Rubicon Express. They tie back to the transmission mount and are gusseted.
The XJ rides and drives really nice with no death wobble or tie wear. The bushing just bothers me since it really isn't seated exactly where it should be. I thought the IRO part might fix that.
Old July 12th, 2017, 17:42
TRAILREADYXJ's Avatar
TRAILREADYXJ TRAILREADYXJ is offline
Re: 10mm or 1/2"
The only disadvantage, if you call it that, to swapping to a 1/2" joint is that you need to drill your UCAs to 1/2". This really would only be an issue if you ever plan to resell the arms or something if you upgrade to a LA setup.
At the same time, with that setup a 10MM bolt is sufficient, so it's really just a personal preference.
96 XJ, 4.0, HP30 / 8.8, Lock Rights F&R, Clayton 3 Link LAs, 4.56, 35s, and a few other things.
10mm EAA Witness Compact $425 w/pic Mosephus Red River Chapter For Sale/Wanted 6 August 9th, 2015 14:42
help, stranded 405 n westminster! need 10mm socket GrimmJeeper SoCal Chapter 13 June 11th, 2010 13:31
IPF 10mm Light Locks - Brand New HQuakers NAC Classifieds 0 August 22nd, 2009 20:49
SYE install, stripped 10mm bolt... St3mpy Modified Tech Discussion 9 September 29th, 2005 18:16
