Old March 23rd, 2017, 14:48
01classicxj's Avatar
01classicxj 01classicxj is offline
4wd conversion...just saw a couple of issues..
Hello all. I am closer to starting on the finish of my 2wd to 4wd conversion. So i went to my storage to look at the 1999 tranny/transfercase sitting there. They are still mated. Wiring harness, dipstick tube in there as well. Pulled both driveshafts off to make handling easier. It's laying across a four wheel dolly. My question is about hooking up the speedometer that the sensor is now in the transfer case. It has three spade connector and what is the other big round thing with a plug sitting straight up on the transfer case. I crawled under my cherokee and looked at the 2wd connections. It seems that my speedometer connection might stretch further back once i install the 4wd tranny /transfer case. I unplugged my 2wd connection and it has three spades as well. Is this correct?
Old March 23rd, 2017, 15:44
Francesco Francesco is offline
Re: 4wd conversion...just saw a couple of issues..
When I did my 4wd swap, I took out the entire sensor from the tailshaft, as my donor tranny had an electronic one, and mine was cable, and installed my entire unit from the old to the new. Hope this helps.
Old March 23rd, 2017, 16:58
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
I swapped the sensor from my 00 2wd trans into whatever t-case i swapped in and went with it
Old March 24th, 2017, 20:02
So i figured out the other connection on the transfer case might be the VIC. I can get away with not hooking that up right? I dont think it directly effects the 4 wd system. I dont need a light telling me what range i'm in.
Reset ECM, solved a couple issues at first. Pchitti OEM Tech Discussion 16 February 10th, 2015 18:04
I have a couple of issues.... techno1154 OEM Tech Discussion 3 August 12th, 2014 19:36
Couple issues Apostle Colorado Chapter 3 December 2nd, 2010 11:03
84 pioneer has a couple issues... thechief86 OEM Tech Discussion 9 September 25th, 2010 19:07
Couple renix issues.. GarageAlchemist OEM Tech Discussion 12 January 11th, 2010 16:00
