Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Cherokee XJ (1984 - 2001) > Modified Tech Discussion > Paint and Bodywork forum
Paint and Bodywork forum Around here sheetmetal is optional but if you are going to do it, do it right.
Old February 27th, 2017, 16:37
orangetrek's Avatar
orangetrek orangetrek is offline
Regretfully looking for opinions
Below are a few pics of what im up against trying to make a bush rig out of my 99 xj (going out to catch a trout and the like). I bought this thing in 2005 and for the past few years she's been laid up (in less than ideal conditions obviously) and ive been looking forward to getting 'er back on the road.
I wasn't going to bother posting pics of this heap but at this point i think i need some unbiased perspective.
passenger side
Front drivers side
Interior
Ive busted off 90% of the bolts that are removed.... do your worst folks, greatly appreciated
Old February 27th, 2017, 16:50
orangetrek's Avatar
Re: Regretfully looking for opinions
... ive got ruffstuff front and centre stiffeners in the mail to help the frame
Old February 27th, 2017, 19:33
orangetrek's Avatar
Gas tank armour. 4 - 17mm and 2 - 18mm bolts. Only one broken. Things are looking up.
Mufflers not supported now...
Old February 27th, 2017, 22:22
orangetrek's Avatar
Ok. Im figuring nothings beyond fixing. Love the forum. Appreciate the lack of input. Means i should keep going
Old February 27th, 2017, 22:49
Hypoid's Avatar
Hypoid Hypoid is offline
Please excuse my state of shock. Is this amount of rust common for Newfoundland?
Do you know how to weld? Do you own a MIG welder? You can order all kinds of body parts. Hopefully you have something to attach them to.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old February 27th, 2017, 22:54
orangetrek's Avatar
I have a welder. Im a little ways away from figuring out what exactly i have to do here. This rig wouldnt have lasted so long if only in NL. In ON until 2007
Old March 1st, 2017, 10:55
Kittrell's Avatar
Kittrell Kittrell is offline
You can get a whole new floor pan or try to patch what you have.
Full Floor Pan
Individual Floor Pans
You can do a rocker replacement and I would just swap out the doors for healthy ones.
2x6 Rocker Replacement
I know you already ordered stiffeners but these guys make the best version out there.
Full Stiffener System
Not something you mentioned, but something I noticed. You can get this to replace your broken center console bracket.
Bracket
Old March 1st, 2017, 11:50
old_man's Avatar
old_man old_man is offline
I hate to say this, but it needs a lot more than a floor pan. The "frame rails" appear to be toast as well. If the drive train is still good, I would look for a body only and swap every thing over. I did this when my I taco'd my old rig. As it turns out, I snagged a body only from a club member for hauling it off.
The shear amount of work replacing all the sheetmetal and getting the structural integrity back could end up taking multiple hundreds of hours, not to mention the cost.
It would be worth it to drive a few hundred miles and drag a different body home on a rented trailer. You life would be a ton easier and you would start with a known quantity. Just the cost of getting all the sheetmetal, getting everything sandblasted, and the metal stabilized, could run you $1000. Around here I can snag you a running vehicle with minimal rust for maybe $1500.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old March 1st, 2017, 11:54
notamos's Avatar
notamos notamos is offline
I wouldn't touch that with a ten foot pole. There's nothing there that is worth your time/money. I'd find a new<er> one w/ MUCH less rust. That thing is terminal, call hospice.
Old March 1st, 2017, 12:32
orangetrek's Avatar
Full Floor Pan
Bracket
Those stiffeners look like a better option for sure... i should have done more research. The more i tear away from the thing the better idea ill have just exactly what im dealing with. Thanks for the links!
Old March 1st, 2017, 12:40
orangetrek's Avatar
The only absolutely terrible portion of the rails seem to be in the front, hoping the stiffeners will bridge the structural gap. I dont mind spending the time getting it back on the road but there may come a point when the expense will shut this project down.
As for getting a new body im afraid id probably have to travel off the island to find one. Im going to have a look atound though as a contingency.
Thanks for the input!
Old March 1st, 2017, 17:03
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
It might be a lot easier to take a vacation and find a body without the cancer.
That's awful amount of rust.
Good chance that many of the embedded nuts, the ones that the leaf springs, shackles and crossmember use, will strip or break loose and spin, adding many extra hours of work to repair.
Assume there is rust damage in places you can't see, up inside the unibody.
I would think the whole unibody is compromised.
How do you plan on using the XJ, once in operating condition?
Both Cherokees are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
2001 Sport, 4 " lift, 33 X 10.50 KM2, DB, R.E.-UCA, JKS-LCA, ACOS, SYE, 4.56-8.25 TruTrac-D-30-E-Locker both with alloy shafts, Hidden M8000 winch, Vanco/Sport-Trac front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, Towing baseplate
Old March 1st, 2017, 17:18
Hypoid's Avatar
Originally Posted by lazyxj View Post
It might be a lot easier to take a vacation and find a body without the cancer...
Keep in mind, the OP is in Canada. It may not be so simple, or so cheap for him to do the things that people "South of the Border" will do.
None the less, that is a lot of rust!
Old March 3rd, 2017, 19:58
orangetrek's Avatar
Some shot of the doors...
Drivers back is the last pic...doors are sound.
Picking at the "chassis" this evening.... i think shes salvagable!
Old March 3rd, 2017, 20:03
orangetrek's Avatar
Rear drivers side lug trouble ...
Beat the voids with a wee cold chisel then..
Its a labour if love... has to be eh
Opinions on this MJ? IslanderOffRoad SoCal Chapter 20 March 7th, 2012 04:39
Can I have every ones opinions please... navyblue123 Colorado Chapter 61 August 25th, 2010 21:15
Looking for opinions AppleValleySlim SoCal Chapter 16 July 19th, 2007 15:25
Need Cat Opinions black2door OEM Tech Discussion 6 December 8th, 2006 22:06
Opinions on an MJ? Phil Non-Tech / Off Topic 8 April 1st, 2004 20:16
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
