Old January 26th, 2017, 19:20
2000heepxj 2000heepxj is offline
Broke upper rear shock mount *BUT THERES A CATCH*
So after a couole years of having this 2000 xj i recently had and rear shock mount break on the drivers side. Not only is it the upper, but the idot before obviously had it break on him so instead of fixing it correctly he welded the hell out of it. Bolt and all. Looks like one big piece of popcorn. Well this is something that im bot capable of fixing due to not having the tools. I cant just punch it out and fish a bolt through. So i took it to a buddys house to have him look at it and i get word that its something that he dont feel comfortable digging into (dude is fabricator and worked for Roush) so long story short before going to pick it up has anyone else ever ran into some crap like this before? Any ideas were to go from here? Any help would be appreciated. Im new to this whole forum thing so deal with me, as i will try and get pics up soon as i figure it out. Thanks guys
Old January 27th, 2017, 09:56
Re: Broke upper rear shock mount *BUT THERES A CATCH*
Old January 27th, 2017, 13:09
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
your picture is not working.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old January 27th, 2017, 13:30
dan1977p's Avatar
dan1977p dan1977p is offline
Lots of folks have issues with those capture nuts breaking loose and end up cutting access holes from above. Probably your best bet after cutting the existing stuff off.
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
Old January 29th, 2017, 13:44
XJensen's Avatar
XJensen XJensen is offline
I cut access holes and re welded the nuts in my last jeep then welded the flap back up. Spent way to much time on it. This time around I used a 3/4"hole saw or close to it and opened up some holes for good. I have just enough room for the socket and took 10 minutes.
-------- www.4x4TrailMaps.com --------
Old January 29th, 2017, 15:32
jeep ride's Avatar
jeep ride jeep ride is offline
Rough country makes a repair kit for broken upper shock bolts cant think of what they call it
Old January 29th, 2017, 18:11
OutkastBoss's Avatar
OutkastBoss OutkastBoss is offline
There are already holes to access them from underneath, punch out with bfh or air chisel. Then fish bolt in above with wire or taped to an open ended wrench. When they are just stripped you can drill them out and there is room for another nut on top of the old one. If you search google about it and put in the search you will find a bunch of posts about it, some with pics!
If it were me since you have the chunks of weld in the way I would use a cutting disk on an angle grinder to cut below the welds or grind down past them with a grinding rock. ( even if that means grinding it flat). Then I would punch out and replace as usual. Never understood why so many people cut holes when there is access to get at them slightly inboard when you are underneath.
Very common problem on these.
M.W.C. Director At Large
01 XJ
http://www.naxja.org/forum/showthread.php?t=1080904
XJ Expedition trailer
http://www.naxja.org/forum/showthread.php?t=1103987
Old February 3rd, 2017, 14:30
paddlernate paddlernate is offline
Clearly and Advanced Fab and Engineering issue. Please ask what tire size you should run with your new shock bolts next.
Old February 3rd, 2017, 19:44
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Sierra Chapter Treasurer
Seriously. Why is this here.
Old February 4th, 2017, 07:49
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Cut the newbie some slack. If you can provide some helpful info, or encouragement, do so, otherwise ........
heepxj, grind the booger welds flush using appropriate eye and face protection, and use whichever of the suggested fixes meets your needs and skill level. I always knock out the welded nuts and fish in hardware store bolts/washers with a length of wire.
Originally Posted by bimmerjeeper
Blanket caught in the rear liftgate latch. Now I can't open.
Old February 4th, 2017, 17:19
blakews2217 blakews2217 is offline
I broke all 4 on mine. What I did is Redrill and tap them. Can't remember the sizes but it's working right now.
Old February 4th, 2017, 17:42
jeepingben jeepingben is offline
If you really never want to deal with those bolts again...
http://naxja.org/forum/showthread.php?t=1116407
Rear shock upper mount broke by itself Slonopotam OEM Tech Discussion 2 November 4th, 2015 12:12
Broke all rear upper shock mount bolts robhurlburt Modified Tech Discussion 44 October 6th, 2011 20:13
help broke bottom rear shock mount gabe4 OEM Tech Discussion 10 June 24th, 2008 06:41
...NC... RE 3.5-4.5" REAR Monotubes AND JKS Upper Shock X-over Shock Mount uncc civilengineer For Sale: Private Party Only. XJ ITEMS ONLY 10 December 18th, 2007 18:40
upper rear shock bolts broke xraydivr OEM Tech Discussion 25 March 20th, 2007 18:45
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
