SolarBell
- Wheat Ridge, CO
I haven't seen a lot of this out there so I figured I'd start a thread on it. I'm attempting to put an Eaton M90 supercharger into a 2000 XJ without cutting the hood or removing the A/C. (Hence the 'shoehorn')
Couple of notes before I start:
- This is going to take a while. If I get done by spring I'll be happy.
- I do not have the skill and experience like Talyn or O-Gauge-Steamer. I'm learning as I go.
- Please no pissing matches in here. If people start pulling that, I'll ask the mods to delete the thread and I'll take it elsewhere.
What I'm starting with:
2000 XJ with 172k on the body and 50k on the motor (Replaced due to a failed head and coolant in the oil)
California-spec emissions (3 cats, 4 O2 sensors)
62mm throttle body
Dynomax cat-back exhaust
AW4 transmission
242 transfer case
Dana 30 / 29 spline 8.25, 4.56 gears
4" lift
33" tires
This started when we bought a pop-up camper. At 3300 pounds it tows like a dog, especially in the mountains. After running the numbers, adding horsepower is more cost-effective then replacing it.
I had looked at the RIPP supercharger kit, the Sprintex kit (if I could even find one), and the Rimmer eBay M62 installation kit. I also sat down with O-Gauge-Steamer for a couple hours talking pros, cons, and options. I'm lucky, he lives 10 minutes from one of my work offices. After even more research, I decided the best option was to try to come up with my own. I found some threads where people had deleted the A/C compressor, but my wife likes the A/C when we're driving long distance in the summer so I'm going to try and avoid that.
I found a local guy selling an M90 out of a Ford Thunderbird complete with intake and output fittings. Since I'm going to be putting the SC on the passenger side, having the intake and output fittings saves me a bunch of fabrication work. My initial tape-measure sessions look like I might be able to install the M90 so the snout is below and slightly outboard of the A/C compressor. I will probably need an idler pulley to make sure I get enough wrap on the M90 pulley. I will have to relocate the battery to the back and the coolant overflow bottle to the corner the battery came from.
Other note - I am specifically upgrading to larger injectors rather than running a seventh injector. It's just plain cleaner.
Here is what is on the parts list so far:
Eaton M90 from a Ford Thunderbird (have)
3" Intake piping
AEM F/IC-6 controller
Venom 30# injectors
AEM AFR, boost gauges (have)
PCV oil separator
Full set of frame stiffeners
Rear lunchbox locker
Sealed battery mount / case with cabling
I realize some of this should have been done a while ago. Oh well, now's the time.
The majority of the fabrication is going to be the mounting of the M90 and the probable idler pulley. The intake of the M90 will need to be modified to fit in the engine bay and to locate the throttle body. I need to make sure I retain the bypass valve and have plenty of vacuum ports.
I realize cooling will be an concern. I have already put in an aux fan-driven Derale transmission cooler to offload the transmission cooling load. I just went over the entire system with a flush and new cap and thermostat. I cool pretty well with the stock single core radiator so I'm going to leave that for now until I run into issues.
Here is where it all begins. I have already started tearing it apart to rebuild it. I found no oil in it, and all of the lobes had oil on them so I need to get it completely apart, cleaned, and rebuilt. I feel a touch of rubbing at one spot in the revolution so I'm probably going to replace all of the bearings in the process. Of course the gear plate between the snout and the main body doesn't want to separate from the main body..
62mm throttle body
AW4 transmission
242 transfer case
4" lift
33" tires
3" Intake piping
Venom 30# injectors
PCV oil separator
