96 XJ 4wd Pre-Runner for #1706 DJ Racing
Specs:
96 Jeep XJ
Drivetrain:
Ford 302, fuel injected, moved 7" to rear, custom firewall
Art-Carr C4 Trans, Reverse manual valve body, low ratio planetary set, 300M main shaft, Art-Carr shifter
Atlas II transfer case 3.8:1 ratio
Axles/Suspension:
Dana 30 front axle, trussed custom mounts, Detroit Locker, 4.88 gears custom 6 lug dana 44 hub conversion and brakes
Rubicon Express long arms, custom crossmember
Rubicon Express 5.5' coil springs
King 2.5"x12" double bypass shocks, strapped at 13" of travel
Radflo 2"x4" hydraulic bump stops
Ford 9 inch rear axle, trussed
31 spline Dutchman chro-moly axle shafts
4.88 gears, Detroit Locker, disc brakes
4 link trailing arm suspension, 1 1/4" heims everywhere, except bushings at frame side of lowers
King 2.5"x14" coilovers
FOA 2.5"x16" triple bypass shocks, strapped at 18" of travel
Interior:
Full roll cage, from front bumper to rear bumper (lots O' tube)
Custom sheet metal dash with gauges, switches, resettable circuit breakers, Lowrance 540C GPS, Kenwood Race Radio, Rugged Radios Intercom and headsets, XM satellite radio, Link-Arc on-board welder mounted in dash, co-dog telescoping handlebar
Kirkey aluminum race seats
PRP 5 point harnesses
Extras:
(4) VisionX HID's on upper light bar Converted with Baja HID kits
Hella headlamps with Baja HID kits
(4) Kragen 4" HID's on front push bar
37x12.50 17 BFG KR project race tires or 36x13.50 16 Interco Irok's on Champion bead locks
Hanneman fiberglass fenders and bedsides
Rear amber collision light
More build pics here
