BrettM said:DOM is stronger, and 4130 (or 4340) is even stronger. Do you want percentages or something?
cracker said:I have heard from numorous people that DOM is not any more dent resistant than HREW...
Capt. Nemo said:Same ones who sold you the kingpins???
BrettM said:get the specs for the steel from your supplier, if the tensile strength is higher on the DOM (which it should be!) then it is stronger for denting also.
Weasel said:denting is different then tensile strength. Tensile strength is the strength as it's applied in tension hence the name. Denting has to do with impact strength. DOM and HREW should be pretty close to the same, except HREW will of course have a seam which might be a less on the seam. Otherwise I don't realy see a reason they should be different. Dent resistance should come more from the composition of the steel, most DOM and HREW are 1018 or 1020.
here s blurb on standardized testing for dent resistance:
http://www.sae.org/technical/standards/J2575_200406
i could have sworn that is what i told him about 2 months ago :lecture: ( not word for word but close ) some people you just cant teach!! :doh:CartsXJ said:Ding ding ding we have a winner.........dent resistance is completely different than what the tensile strength of the material is for. I bet if you take a hammer to the same OD, wall thickness tubing of HREW (not on the seam), DOM and 4130: the HREW and DOM will dent the same and with a little less denting on the 4130 because of impact dispersion and rebond characteristics of 4130.
This is why you don't see guys running thin wall 4130 lower links, they will have a higher tensile strength compared to DOM, but will fold on the first rock.
cracker said:So I have heard / read different opinions on this. Can please someone clear this up?
Captain Ron said:It's more a function of velocity and the rock you dent your tube on, as much as the tube you dent on the rock.
luvrox said:No numbers to offer but experience says 4130 is by far the toughest; Dom is next in ability to withstand dents and slide over rocks. Crew will dent, gall and tears rather than slide over rocks. My new chassis is all dom on exterior tubes.
P/s - - One caution a lightweight 4130 welded chassis will develop stress cracks in time. Then comes the question will you have a service truck there with a tig welder to do repairs?
luvrox said:P/s - - One caution a lightweight 4130 welded chassis will develop stress cracks in time. Then comes the question will you have a service truck there with a tig welder to do repairs?
Weasel said:This is not true, is you develop crack it will most likely be due to a poor design not 4130. And you do not need a TIG welder to repair 4130. Mig will work just fine. 4340 is a different story though and when welded usualy forms a state in which crack can occur.
