Old August 29th, 2009, 09:12
dagr8tim's Avatar
dagr8tim dagr8tim is offline
AC Line Removal
I'm working on a 98 Sport, and I'm trying to remove the AC Lines. I got the bolt out where the block connects to the compressor, and where the nut where the stud attaches to the tank near the firewall. How do I get the line off that goes to the condenser in front of the rad?
It looks like some form of clip.
Old August 29th, 2009, 15:18
zr2toxj's Avatar
zr2toxj zr2toxj is offline
Re: AC Line Removal
You need a special tool to release the internal spring:
Old August 29th, 2009, 17:45
dagr8tim's Avatar
Re: AC Line Removal
Thanks, being as this is my parts Jeep, I may try to cut the line just past the joint.
Rear brake line removal RShotl OEM Tech Discussion 4 October 14th, 2007 20:58
ac line removal.... xjeepster OEM Tech Discussion 3 August 2nd, 2006 13:31
removal of clutch line from slave 91 jeepmadness OEM Tech Discussion 9 July 8th, 2006 01:16
Radiator Removal - Transmission Line critik OEM Tech Discussion 2 July 25th, 2005 20:20
Tranny cooler line removal? Incredible Hulk OEM Tech Discussion 3 December 22nd, 2004 01:10
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
