Old January 10th, 2018, 12:10
bjoehandley's Avatar
bjoehandley bjoehandley is offline
Replacement Fuel Lines
Does anybody make bolt in replacement fuel lines for the '97-'01 XJ? Mine has been parked a while and I threw a new battery in it so it was usable and it started leaking fuel shortly after firing and there was still a gas smell when I got in my 200 to go to work this morning. We did have issues with the line that was tied into the evap system and Dad fabed something up since we needed something quick and it was the weekend with no obvious parts available at that time, so I'm thinking there is a good place to start looking.
Old January 10th, 2018, 12:22
PacificEd's Avatar
PacificEd PacificEd is offline
Regular Joe
Re: Replacement Fuel Lines
Are the lines rusted or are the O-rings bad in the coupler where it meets the fuel rail? My '94 leaked at the rail and I would get a light fuel smell while driving. Look for a wet coupler.
Omix-ADA 17732.30 is the only hard line I found in a quick search.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Old January 10th, 2018, 13:50
Not sure, I did the work after 6pm last night and it was dark out. I did shine my phone's flash light in the area of the duel system, but didn't see anything obvious at the time.
Old January 11th, 2018, 08:13
Heavyopp Heavyopp is offline
I'm thinking if I had to replace my fuel line I would swap over to stainless steel braided hose and AN fittings -- I wouldn't trust anything "factory"made from china or mexico not to leak
I know it will cost, and probably overkill but it's a job I would only want to do 1 time
Old January 11th, 2018, 17:44
As much as I'd love to, it's not really worth the time and money to do any more. I wouldn't be surprised if some places would recommend scrapping it if it takes fabbing something as a replacement.
Old January 11th, 2018, 19:30
I guess thats a decision only you can make -- No way I scrap my XJ for a fuel line issue
Rust,rot, accident are the only reasons I can think of -- everything else is fixable
I personally don't care for all the computer controlled crap in a newer vehicle and will fix my xj till I can't regardless of cost
Old January 11th, 2018, 19:39
It's got plenty of rust, having spent most of it's 20 years in the Chicagoland area, that's what would make it iffy in some eyes. It's no longer my daily, but I would fix that rust if funds presented themselves.
Old January 11th, 2018, 20:06
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
You can safely replace cut-out fuel line using SAE R10 fuel hose and clamps, IF you bubble flare the cut ends.
My 96 had the fuel filter connected with R6 hose from the factory, but even it held for 20 years until I replaced it with R10.
Renix fuel lines to 91-95 fuel rail? AIbandit Modified Tech Discussion 5 June 17th, 2014 16:53
Replacement fuel pump/fuel filter/gas tank? 2000NWXJ OEM Tech Discussion 2 September 26th, 2013 18:57
Replacement Vacuum lines Renegade XJ SoCal Chapter 3 November 14th, 2012 14:56
replacement trans lines BenDiesel OEM Tech Discussion 5 March 18th, 2010 09:29
Replacement vacuum lines RollTider OEM Tech Discussion 9 August 27th, 2009 05:27
