Old August 10th, 2017, 19:13
ehall's Avatar
ehall ehall is offline
infrared gun oil pan temps?
Any of you with an infrared gun willing to take oil pan temps?
My passenger side seems to run about 180, but the driver side next to the downpipe is 220ish
my '91 beater rebuild
Old August 12th, 2017, 16:58
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: infrared gun oil pan temps?
I had that problem (or thereabouts) when the PO had reused a bad exhaust flange gasket at the manifold to tail pipe gasket. My main overheating, and low oil pressure problem was when I came to a stop, only after getting off the freeway from a 1 hour drive, at a stop light. When I replaced that gasket my oil filter and coolant temps dropped about 20 F. And the Min oil pressure increased about 7 psi. The leak was mainly at higher rpms under load, which is why the 3 muffler shop inspections missed it for 3 years.
40 F difference is significant, very significant unless there is no oil in the pan..... You got me thinking again of putting a ceramic insulating pad on that side of the oil pan on mine. Or two steel clamps clamping some insulation just on the oil pan side of the pipe? I was about to do that to the 96 Ford Taurus before my son sold it. It had the pipe "3/4" from the damn oil filter between the engine and radiator.
The infrared radiation from the pipe may be part of it and the proximity to the oil pan never made any damn sense to me.
All my temp tests focused on the oil filter housing temp while the engine was running with the infrared tester. Have you tested it to compare???
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old August 12th, 2017, 17:12
Tbone289's Avatar
Tbone289 Tbone289 is offline
Where did you take your measurements?
I went for a 20 mile drive after some maintenance this morning to heat up my AW4 and check levels. I crawled back under to take IR measurements when I got back home as it was idling in the garage:
Driver side: 180
Passenger side: 170
I took my measurements at the front lower corners of the sump. If I tried to take a temp measurement between the tubes of the header, it was around 205. I don't feel like that is really an accurate measurement of sump temperature though, as the pan is likely radiating a lot heat from the header at very close proximity.
Old August 12th, 2017, 19:57
ehall's Avatar
Thanks for the reading and info
Having some engine temperature issues and looking at ways to reduce. May do a remote filter and cooler to try and pull some heat off.
Jeep Runs Cool....Need infrared temps confirmed XJTowerDog OEM Tech Discussion 7 February 26th, 2014 11:23
Infrared Pic of an outlet bigalpha Non-Tech / Off Topic 24 October 18th, 2010 18:39
FLIR Infrared 4.0 Photos HOT/COOL topic Ecomike OEM Tech Discussion 3 June 19th, 2007 22:27
Rising Temps Limited89XJ OEM Tech Discussion 16 June 5th, 2007 14:16
what temps do my AUX fan come on at ? dan89XJ OEM Tech Discussion 15 June 27th, 2005 21:03
