Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > Modified Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old August 9th, 2017, 18:58
MadMachinery MadMachinery is offline
Dana 44 Swap Questions
Hey guys, first post! Hopefully this is in the correct section of the forum. I have been wanting to swap out my rear D35 for a while now. My intentions were to get/build a D44 with 4.56 gears and a Detroit locker. Well after a while of searching for a dana 44...I stumbled upon a D44 with 4.56 gears and a Detroit locker for sale online. Lucky? Maybe. I was looking for some opinions of what you guys think of this axle. What are some things for me to check out/test while looking at the axle? What would be the going price for this sort of axle? All the same D44's with the same setup I see going for 1500+, but the seller is looking to get it at half that price. I want to make sure that my limited knowledge is not getting in the way and that this is not a deal that is too good to be true.
Old August 11th, 2017, 12:06
old_man's Avatar
old_man old_man is offline
Re: Dana 44 Swap Questions
Looks like it had water in it at one point. The rust on the gears is worrying. If you do get it, take it real easy for a few days and change the oil every 50 miles or so for three or four times. I would also look at the bearings.
Pulling the axles and the carrier to take a look and most likely just going ahead and replacing the bearings and really cleaning off the rust on the gears might be prudent. Without a written guarantee, all I would probably go would be $500. There is a fair amount of risk involved.
Tom Houston - Former Colorado Chapter President & Terminal Adrenaline Junkie
Loveland, Colorado
You're just jealous because the voices don't talk to you.
Old August 11th, 2017, 12:30
Anak's Avatar
Anak Anak is offline
Mostly Harmless
In addition to the rust it looks like you will at least need to do something with the shock mounts.
Is that supposed to be an XJ D44 or from something else? Correct width?
Old August 11th, 2017, 17:23
srb531 srb531 is offline
the dynatrac axles & detriot , are worth the price alone, even if you have to get some new bearings & seals. is the width correct for a xj ? id be measuring it.
Old August 12th, 2017, 08:14
comanche91's Avatar
comanche91 comanche91 is offline
By all means, measure it. WMS - WMS XJ and MJ = 60.625". It looks longer to me in your photos.
Spring Perch Measurement
Old August 12th, 2017, 09:12
comanche91's Avatar
Old August 13th, 2017, 06:34
Originally Posted by comanche91 View Post
In his ad it says, "Measurements 61" from backing plate to backing plate
22" to the center of the leaf spring perch off center of the differential
15" to the center of the shock mounts off center of the differential"
I asked him to get me the lug pattern and BOM number before I even check it out. If it's an xj 44, I will probably buy it. If not, I think I'm going to go with a 8.8. I have been researching and I think it would be more worth it to go to 4.88 gears with 35s, so unless its an xj, I don't see it being worth it.
Old August 14th, 2017, 22:02
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
The rust on the locker to me is more worrisome then the surface rust on the gears....
Old August 15th, 2017, 00:57
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
for that price I would take it,
pull the carrier and make sure the bearings aren't toast from the rust.
clean as much rust off the gears as you can with a wire brush and run it.
change the oil after a couple hundred miles.
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
dana 35 to Chrysler 8.25 swap questions dfjeepster Modified Tech Discussion 16 March 7th, 2010 08:07
dana 44 swap questions themud Modified Tech Discussion 5 March 25th, 2009 20:55
99 dana 30 to 44 axle swap questions... 99 4.0 beast Modified Tech Discussion 9 July 14th, 2007 17:14
Dana 44 Swap/Brake Questions jeepster91 Modified Tech Discussion 1 March 14th, 2006 18:38
Front Dana 30 Swap Questions? jeep_87_cherokee Modified Tech Discussion 6 October 17th, 2005 20:24
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
