Old August 26th, 2016, 22:33
rockclimber's Avatar
rockclimber rockclimber is offline
Associate
Re: Project Unicorn - a light duty trail rig
Not 100% sure at this point, but somewhere in the ballpark;
4" lift (4" deaver leafs, shackle relocators, 4" pac coils)
JK Rubicon 44's front and rear
4.88 gears, 35 spline rear, 32 spline inner/outer front
33" AT's
Atlas 3.8
I'll let Russ whisper to the motor and see what happens there, but we can be sure something will go down.
As far as bumpers, sliders, etc - what's available has changed so much that I really have no idea what is out there anymore. As much as it sounds contradictory to say when you're talking about 300 horsepower and an atlas on JK axles, I mean this to be more of a commuting and camping rig - just built to where it won't break or wear things out quickly.
I do really want a Genrite gas tank for it, but I can't see myself paying the price.
If I were doing sliders/Armor again I think it would be these
http://www.jcroffroad.com/product/XJ/XJSL-CR.html
http://www.jcroffroad.com/product/XJ/XJQU-RR.html
[cal]You're an idiot rockclimber.
[StinkyFab]RockClimber is a tool.
Old September 20th, 2016, 07:58
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Since doing the atlas swap, I've had some driveline vibes at highway speeds.
I assumed it was pinion angle, since I'm running a CV driveshaft but have the rear end in the stock location; so i grabbed some shims and set out to adjust it.
Once I got it up on jacks and pulled the tires though, the pinion angle looked pretty good to me (I remember looking at it when I did the install and thinking it should be fine..?). So I tossed the jeep in gear and let it run. There was *massive* run-out on the driveshaft.
OOPS.
Pulled it hoping that maybe Ray at OC Driveline can balance it out for me, as I really don't want to drop $350 on a new driveshaft right now.
Ray chucked it up and found it was bent, with just under 3/8" runout. crap crap. I don't want to have to retube it but it seemed inevitable
Ray looks at me and says "no problem, i'll straiten and balance it. $55."
..what?
i guess once i thought about it, its no difference from straitening an axle housing; i just never considered it before. He was nice enough to let me take some video for you guys.
Heating it up and quenching to move the tube.
He did that 4 times in 4 places on the tube, but I only shot video once.
The machine is basically a cradle with a dial indicator on both ends. This was after the last straiten, during the balance process.
Here he's spinning it up to 3500 RPM's to check the balance after welding the weights on.
I can run the jeep up to 85 and there are no driveline vibes at all; before it was pretty apparently after about 45.
.... now my rear end appears to be going out - probably from the vibes. Need to find myself an XJ44.
Old September 20th, 2016, 08:40
rum_maximus rum_maximus is offline
A ZJ gas tank will plug right in to replace the XJ tank and will get you a hair over 25gal. Not quite the +10gal that the GenRight will give you, but getting an extra 5gal capacity for about $40 or so let me put some $$$ elsewhere.
XJ on the left, ZJ on the right. I threw in a new fuel pump while I was doing the swap since the old one was on the way out. Part #s on both the old pumps were the same, so I bought a Bosch 67658 on Amazon (www.amazon.com/gp/product/B001C6023G).
I threw 2.5gal in the empty ZJ tank to get me to the gas station down the road from my house, then pumped a hair over 23gal to fill it up.
Old September 20th, 2016, 09:06
cal's Avatar
cal cal is offline
Which gas tank skid did you run?
Old September 20th, 2016, 09:21
Haven't put a skid plate on there yet, been looking for an OEM one from a junkyard or someone parting out so I can test fit (on the cheap) to see if there are any issues clearing the ZJ tank. From reading thru the original thread where RedJeep2.0 did the swap, it looks like they both hang down the same amount. So hopefully the XJ skid "should" bolt right on.
Unfortunately all my $$$ lately is going into a custody fight over my daughter instead of into the XJ.
Old September 20th, 2016, 10:16
Joecam18 Joecam18 is offline
Do you have a link to that RedJeep2.0 thread?
Old September 20th, 2016, 10:23
http://www.naxja.org/forum/showthrea...1122906&page=3
Gas tank swap starts at post #39, towards the bottom of the page.
Old September 20th, 2016, 11:29
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
I'd love to know if the factory XJ fuel tank skid will fit over the ZJ tank.....I see this in my future, as I'd love to extend my range by 5 gals.
Speak the Truth-Question with Boldness-Speak without fear.
Old September 20th, 2016, 11:40
cal's Avatar
cal cal is offline
I imagine the factory ZJ tank skid would. I have seen a few people run the ZJ skids with an XJ tank, seemed to bolt in with minimal work.
Old November 27th, 2016, 16:06
cal's Avatar
cal cal is offline
For as long as I've had this jeep, its always run cool.
Now that its getting cold out, I also discovered I had no heat. Which isn't a big deal in SoCal, but no defroster really is a problem.
Pulled under the carport and drained some coolant.
Pulled the thermostat. It doesn't close all the way.
New 195* thermostat. New housing. Flushed the heater core backward while it was apart.
Everything works great now.
Boring update, but I've been working on other projects.
Old January 25th, 2017, 09:50
Kittrell's Avatar
Kittrell Kittrell is offline
Re: Project Unicorn:
The underside of this jeep is as clean as the top.
Old January 26th, 2017, 07:24
XJensen's Avatar
XJensen XJensen is offline
I have a zj gas tank in my Jeep. I used the stock zj skid as well and everything fits just fine. The tank fills most of the additional space in its width, just fits between the rails.
The tank mounts just like the stock zj tank and the zj skid just needed new mounting holes drilled. I don't see why an aftermarket xj skid wouldn't fit either
-------- www.4x4TrailMaps.com --------
Old February 7th, 2017, 08:43
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
14 gauge into the cab, up under the dash, and feeding both the 12v port and the usb ports. The extra switches are just filling holes for the moment, I'm not even sure what they will end up being in the long run.
Any particular reason you ran wiring to the battery for the USB and 12v rather than just running them off the wiring for the stock lighters? Got my switch panel last week but haven't wired anything yet
John V.
01 XJ Sport 2 door 5spd/4WD- 4" lift, 35" BFG ATs, JCR bumpers, Rubi 44, Ford 8.8, 4.56's, ARBs
Old February 8th, 2017, 11:46
cbs_24's Avatar
cbs_24 cbs_24 is offline
Cool build. Strongly considering the ZJ tank swap since my pump seems to be on its last leg and I'll be swapping it soon anyway.
Old February 9th, 2017, 10:23
Goose_XJ88's Avatar
Goose_XJ88 Goose_XJ88 is offline
Subscribing. I really like that switch panel. looks so much better than the typical switch panels most people run. IMHO
Never knew those switches existed.
88 XJ Laredo 8" RE SA, drop brackets, 35s D30/44 4.56, AW4, 242, 7100s, Loganís ft winch bumper, JCR swing out tire carrier, JCR sliders, 96 booster, 97+ mirrors & console (FOR SALE)
99 XJ Limited, AW4, 242, Colombia Edition WJ Seats, Stock. Future 4.5" lift, TnT LA, 33s armor, 231 SYE, D30/44 4.56, rear locker, etc
93 XJ 2 Door AX-15 D30/8.25 3.55 swap, (FOR SALE)
92 MJ AW4 2wd, 97 mirrors. Future 4wd swap, 242, MJ 44, Eliminator Roll bar, Bucket seats, 97+ console
New Project 89 XJ Unicorn zachxj01 North Atlantic Chapter 9 May 26th, 2016 17:39
Anyone use OME LIGHT DUTY leafs? djlarroc Modified Tech Discussion 19 August 10th, 2013 19:39
Project:Unicorn SAMSET Midwest Chapter 27 September 28th, 2012 11:58
WTB light duty truck tires XJwheelman NAC Classifieds 0 June 5th, 2011 15:41
Some light duty mods for a camping XJ terryd Modified Tech Discussion 10 January 11th, 2008 17:50
