Go Back   NAXJA Forums -::- North American XJ Association > NAXJA's Technical Forums > OEM Tech Discussion
Register FAQ Users List Calendar Mark Forums Read
HOME Member FAQ Sponsor Info Rules Donate Bylaws Store Members Chat E-Mail
Old August 9th, 2017, 19:37
Anak's Avatar
Anak Anak is offline
Mostly Harmless
Re: The force was strong with this one, Oil filter nightmares
Originally Posted by Tbone289 View Post
There are plenty of people posting in this thread that are logged in and can't see the pictures...
Yep.
Old August 9th, 2017, 20:55
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
AND are paying members.
I'm sure that the shadow knows.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Calico 4-Link
'87 MJ 4.0 AW4 231 D-44 stock-ish
Old August 10th, 2017, 06:06
dan1977p's Avatar
dan1977p dan1977p is offline
I commented in the other thread. It's 100% the Naxja forum. I wouldn't waste any more time on this until we can get buy in from the BOD to allow us to host pictures here and that someone will look into who gets access to the vBulletin albums.
91 Sport 4.0L, aw4, np231, 4.5" long arm, 33" BFG AT KO's - SOLD
SeXJ Build Thread
Old August 10th, 2017, 11:23
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
OK, screw Naxja, I can get this stuff for free, why bother paying dues for something that does not work here, LOL. Here are the photos, in spite of Naxja,
http://imgur.com/BJTmf9v
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old August 10th, 2017, 11:27
Ecomike's Avatar
NAXJA# 2091
http://imgur.com/rmq3XgS
When all else fails just use a BFH!!
Time to get serious folks. This filter will not win. It's going down for the count!!!
Old August 10th, 2017, 11:57
Tbone289's Avatar
Tbone289 Tbone289 is offline
That's crazy.
I've always hammered a large screwdriver or bar through oil filters that were on way too tight and cranked them off that way, but I'm not sure that would have worked in this case.
Old August 10th, 2017, 14:13
Ecomike's Avatar
NAXJA# 2091
Crazy indeed. That is why I took photos. In my 45 years of wrenching, I have never seen anything like it. I knew when that chain wrench collapsed the filter sides as it grabbed on tight that there was not enough torque or room on the 4.0 for the screw driver through the side method, which I used years ago once or twice on other rigs.
Even with 3 feet of moment arm (cheater pipe-breaker bar) it took 2 minutes of steady force with all my strength to get one full turn on it. I was sure the tool was about to break first.
That's crazy.
Old August 10th, 2017, 14:52
Bent's Avatar
Was the seal wiped with epoxy instead of oil when it was installed?
Old August 10th, 2017, 19:06
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
A little RTV to make sure jiffy lube doesn't have a leaky filter complaint?
Old August 11th, 2017, 16:13
Bent's Avatar
I'll buy that.
I completely forgot about RTV.
Old August 11th, 2017, 19:08
Ecomike's Avatar
NAXJA# 2091
No , just a nut on the other end of the wrench and socket cranking down for all he was worth on that 1" nut on the top of the K&N oil filter, and with the gasket lubed up good, it was even easier to over torque the holyhell out of it.
Ball joint press nightmares Ecomike Tools and Garages 15 April 16th, 2016 11:14
Electrical & bizarre braking nightmares! HELP! semperfi1371 OEM Tech Discussion 4 May 31st, 2011 19:31
Wiring nightmares from the stealership justkain OEM Tech Discussion 5 December 16th, 2010 07:33
Want NIGHTMARES Speedbump96 SoCal Chapter 16 August 18th, 2010 01:52
Electrical nightmares unknown OEM Tech Discussion 4 May 21st, 2003 09:43
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
