Old August 11th, 2017, 13:48
Redsnake Redsnake is offline
Re: 4.6 build starts today!!!
Man that's awesome!! My '01 XJ may need a new motor in a little bit and if this became a 'package' of sorts I'd be glad to know the cost to start saving or heck just order one up...
I wonder if those torque numbers will give the OE drivetrain any issues... :\
Old August 11th, 2017, 14:54
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
Well, today was the big day and it came off perfectly! The guys at Lopers said they hadn't seen such a strong motor!
Max rear wheel horsepower = 227hp
Max rear wheel torque = 396 ft/lbs
AFR's were great with just a slight fattening under 50% dyno load and WOT.
I think I'm done now!
Impressive!!
Speak the Truth-Question with Boldness-Speak without fear.
Old August 12th, 2017, 10:14
RCP Phx RCP Phx is offline
Originally Posted by Jim Malcolm View Post
You're killing me smalls!!! Why did you have to do that? 225 hp/400 ft-lb at mid 9s CR?!?! I need new underwear. Been waiting to see a 0331 based build with dyno numbers and now we know. I think this will start a few conversations...
Question, Chris and Russ, any chance of a "package"? This build sheet, these injectors, this tune, done! Drooling...
Russ will give you a quote on anything/everything your budget will allow. This whole thread is a "build sheet" and I have not done any "computer tuning" even though I have spoke with Chris thru-out the build!
Old August 12th, 2017, 10:17
I didn't set a budget when I took this on, but with my build (with me doing all the work) it ran about 5k!
The Toyota guys put a lot more HP to the AW4!
Old August 12th, 2017, 12:49
Boostwerks.com's Avatar
Boostwerks.com Boostwerks.com is offline
NAXJA Supporting Vendor
Holy crap. Do you have the graph? 400ft/lbs for that HP just sounds almost unbelievable (not saying your lying).
99 XJ Sport Build Thread:
http://www.naxja.org/forum/showthread.php?t=1059015
Check out our website!
www.BoostwerksEngineering.com
Old August 12th, 2017, 12:55
I've got the print outs from the "Dynojet" machine they use.
Old August 12th, 2017, 12:58
Willing to post em up?
EDIT: BTW, what gear was it done in?
Old August 12th, 2017, 13:46
Well that was fun, first my scanner didn't work, then the camera didn't work!
Old August 12th, 2017, 13:47
It was done on a rolling dyno thru all gears and with different loads!
Lopers is one of the best race shops in Phoenix, the shop has been here since 67 and John Loper has been winning drag races even before that!
Old August 12th, 2017, 15:27
Exxon Valdez Jeep's Avatar
Exxon Valdez Jeep Exxon Valdez Jeep is offline
That's nuts
Old August 12th, 2017, 16:04
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
I've never heard of a dyno pull thru all gears? What gear was the 400lbft achieved in? It makes a HUGE difference in the numbers to be in different gears.
Also...where's the rpms on the chart??
88 MJ on 40's. 98 XJ on 35's. 98 Dodge, 52psi of boost. 94 Miata LS4. 70 Buick GS455. 01 Harley, been to 46 states. 05 KTM, 576cc. 06 Husky, girls need bikes too. 2011 R6, girls need sport bikes too. 99 Toyota Avalon, daily. 97 Miata, girls apparently need miatas too.
And everything fits in the garage!
Originally Posted by mako my day View Post
Johnx is #1
Old August 13th, 2017, 07:29
typerr typerr is offline
My understanding is Dynojet (and other chassis dyno) pulls are done in your 1:1 gear to remove any effect of torque multiplication so the dyno operator will shift up through the gears to get to the proper ratio during the session.
Old August 13th, 2017, 08:37
^^^This and without load the motor will not produce it's maximum. I only had a engine dyno and flow bench at my shop but can't imagine all the work that would be involved to run the new EFI motors, back in the day of carbs is was a easy set-up!
JohnX - the RPM's/AFR/Speed and other data is on all the test sessions and I have about 30 pages of print-outs!
Old August 13th, 2017, 13:38
This.
The standard way to do it is use a gear that is as close to 1:1 as mentioned. This would be to lock the trans in 3rd gear or to simply prevent it from going into 4th.
If the trans was in 2nd gear peaking 400ft/lbs, the motor obviously isn't actually making that kind of torque due to the gear reduction.
Old August 13th, 2017, 14:25
Some more info..
The way dyno's work is simply to read torque over a certain RPM range. Given that we know that horsepower is simply a function of torque and RPM, we can find out what the true torque output of the engine is even though the peak numbers maybe skewed given the gearing.
HP = TORQUE x RPM 5252
and
TORQUE = HP x 5252 RPM
Your peak HP number was 227. Not knowing when this peak occured however, I'd have to assume the RPM. Just googling some graphs of 4.6L strokers it looks like peak HP is around 4500-5000RPM.
Plugging in for an assumed 4500rpm peak, I end up with about 265ft/lbs which sounds about right.
Winter on the Rocks starts today SandySteve InterMountain Staging Area 0 January 19th, 2017 10:56
Started my build today. Palmentech766 Midwest Chapter 5 January 20th, 2015 17:00
Jeepers Jamboree starts today..woo hoo rocknxj Sierra Chapter 22 August 2nd, 2008 19:53
No start yesterday, starts today Dirk Pitt OEM Tech Discussion 14 December 7th, 2007 08:03
No start yesterday, starts today Dirk Pitt OEM Tech Discussion 4 November 10th, 2007 09:00
