Old December 30th, 2007, 22:46
Timber's Avatar
Timber Timber is offline
Re: [Tech Writeup] Replacing the seals on your Dana 30
Thank you very much for such a good write up. I'll be referring to this this spring or summer.
Old December 30th, 2007, 23:00
5-90's Avatar
5-90 5-90 is offline
Nice writeup. I'd like to offer some additional advice tho - if you use a wire wheel (in a drill motor or on an angle grinder,) use a light touch! The steel wires that (usually) make up wire wheels are harder than the cast iron used in the housing, and you can very easily gouge the sealing surfaces if you press too hard. While you can use RTV on the gasket to make up for that, why buy trouble? You already have a Jeep - you get plenty of trouble for free...
Sometimes, you can find brass wire wheels at Sears or at local hardware stores in the clearance bins (for about a buck each,) which I prefer to use on sealing surfaces. Also, you can get Scotch-Brite Roloc disks and backing pads at the better-stocked parts houses and hardware stores, which aren't metal at all (and also leave an excellent texture to encourage gasket sealing. Not too smooth, not too rough - I find that the surface texture they leave also helps to encourage head gasket sealing...)
Old December 30th, 2007, 23:43
corbinafly's Avatar
corbinafly corbinafly is offline
"Mmmm. More please."
Good job Mike. That was some gooood carne asada.
Old December 31st, 2007, 10:43
GrimmJeeper's Avatar
GrimmJeeper GrimmJeeper is offline
Dead man walking
Kyung, you layed the most even bead of silicone i have ever seen in my life. haha.
Old December 31st, 2007, 11:47
ScottyDog's Avatar
ScottyDog ScottyDog is offline
NAXJA Member #631
Location: Gardena(90247), SoCal Where the 91/405/110 Fwys come together
Yeah I'd have to agree! Nice touch there Kyung laying down the bead!
Good write up, and the pics do all the justice for dumbasses like me!
Carne Asada?!? Damn if I was only paying attention I would have dropped in at Branden's to help... Or at least eat, drink a couple of beers, and played air drums in the garage band.. LOL
BTW, Do you pick up your Carne Asada at La Venadita in Carson??
Again great job on the write up.
Scott
Old December 31st, 2007, 12:01
kenny811's Avatar
kenny811 kenny811 is offline
Well done!!!! I just did minw last night. Seals, U-joints and a new locker. Im about to go out and finish it up.
Again, well done!!!
Kenny
Old January 10th, 2008, 17:17
Markos Markos is offline
Great writeup!
FYI, you were very close to making life easy when you stuck that socket on the end of the unit-bearing bolt. Check this out:
Just turn the wheel and pop it off. You can that Stu Olson for that tip.
http://www.stu-offroad.com/axle/unit...tbearing-1.htm
Old January 10th, 2008, 18:21
corbinafly's Avatar
Originally Posted by Markos
Great writeup!
I think I like it.
Old January 10th, 2008, 18:26
McQue's Avatar
McQue McQue is offline
Great TECH Writeup!!!
Deserves becoming a STICKY!!
Old January 10th, 2008, 20:40
falcon556's Avatar
falcon556 falcon556 is offline
I have not Confirmed, or I used a BAD email Addy
One question, why remove the driveshaft?
Old January 10th, 2008, 21:08
McQue's Avatar
good point...doesn't look like the driveshaft needs to be removed unless you are going to change the pinion seal while you are in there...
Old January 10th, 2008, 21:38
Dead man walking
sorry i guess i left that out, i was also chasing a squeak that turned out to be in the double cardon joint in the driveshaft... i supposed you could leave it in but hey,
who doesnt want to take 2 mins to pull thier shaft
i was originally planning on changing the pinion bearings as well but it turned out they werent bad, and the seal is only seeping so i decided best not to mess with it... plus im lazy thanks for the comments guys, anything i do to my jeep im going to document now.. maybe it will help someone else who gets stuck along the way.
Old January 10th, 2008, 21:50
sharq sharq is offline
awesome write-up man but why do you want to keep this great tech for your local boys. us east coasters love to read this stuff too.
as far as a local tech forum, i think we need a tech archive section to this forum. im also into hot rods and i frequent the HAMB message board at jalopyjournal.com they have a tech archive that is a vast reference to everything traditional hot rod tech. we need something like that here so great write-ups like these don't get buried in the abyss of threads like "is my cracked manifold a common problem?".
btw, i loved your comic relief.
Old January 10th, 2008, 22:19
Dead man walking
its not so much that i wanted to keep it local, its just that stuff gets lost in the national forums to easily, and nobody seems to care. ive seen some great writeups in the past and they just go away without a second glance. i think it discourages more people from doing them... i mean whats the point, the post is going to be buried in a day anyway. and its a pain searching for this stuff because so many questions get asked about the same subjects that it takes an hour to find what you are looking for. thats the only reason i suggested maybe a local forum, where there are less posts, would be a good idea since the national BOD seemed like they didnt want to deal with it. anyways, without getting into politics too much i just wanted it to be easy to find the writeups, thats all
haha thanks im a jokester, if i take something seriously im pissed
Old January 10th, 2008, 22:40
this is why we need a tech archive. admins can move the worthy posts into this section. its almost like the FAQ sticky but much deeper. it can have those FAQ's and the great write ups that show up from time to time. it could even be categorized, i think this is something that this forum really needs to consider because this forum gets older and there are so many great posts that are impossible to find. check out this great write-up that was never even replied to. must have been posted and disappeared into the abyss of .
anyone have the 97+ dash removal writeup? (replacing evaporator) theksmith OEM Tech Discussion 6 August 31st, 2007 11:11
replacing valve stem seals justright92xj OEM Tech Discussion 5 April 20th, 2006 17:07
Dana 44 Seals SPSERG OEM Tech Discussion 9 June 26th, 2005 17:50
replacing d30 seals Kejtar OEM Tech Discussion 9 May 11th, 2005 07:31
SubFrame Tech Writeup JeepFreak21 Modified Tech Discussion 16 May 25th, 2004 13:50
