Old February 7th, 2018, 10:39
JeepJango JeepJango is offline
How to get more clearance between front diff and frame rail
Hi,
I'm in the process of drilling out the bolt holes for the stock track bar frame-side mount, because the holes are all wallowed out. There are 4 holes: 2 down by the frame rail and 2 in the wheel well. I'm having an issue getting the drill centered on the frame rail holes because the front diff is getting in the way. I need like 3 more inches of clearance. I have the frame rail jacked up until the wheel is just off the ground. What can I do to get the frame rail 3 inches farther from the diff? If I drop the shock, will that create any more flex? or will I also need to remove sway bar and/or LCA? I'm hesistant to remove any extra parts because the rust is so bad they might not go back together. This Jeep is stock but I figured you'd all have experience here. Thoughts?
Jango
Old February 7th, 2018, 12:12
burntkat burntkat is offline
NAXJA Member #1145
Re: How to get more clearance between front diff and frame rail
Uh, remove the wheel and droop the axle? Use a shorter bit or drill?
-89 S-10: SAS, D44s front/rear. 5.7L V8. 700R4 with 4L60E upgrades. Built in my driveway.
-90 XJ 4.0, AW4, 231J: Clayton's longarms, RE 5.5" coils, hybrid 6" leaf pack, 33/12.50/15" MTs, Rancho 99012s and 99624s, Tera HD SYE, custom sliders, BW flares. Rehabbing with D44s, RE spring packs, RE 4.5" coils, and ACOS.
-94 ZJ: Budget boost, 31s. The wife's DD.
-97 XJ: Son's DD. 4" lift, ACOS, 4" spring pack, Upcountry coils, 31s
Old February 7th, 2018, 12:16
trippled trippled is offline
Remove the shock and if you need more the sway bar. Should get you plenty.
Old February 7th, 2018, 12:17
NAXJA Member #1145
More ideas - remove shock, trackbar, and swaybar. If the fasteners break you need to replace them anyway.
Old February 7th, 2018, 22:31
Greenz's Avatar
Greenz Greenz is offline
Disconnect shock from the side you want to drop and take wheel off. Jack up the opposite side. Might get you the 3" droop you need.
Old February 11th, 2018, 08:38
Thanks guys. Everything came apart and went together nicely.
ORI frame clearance? 1-tonxj Advanced Fabrication and Engineering 2 January 31st, 2018 03:36
Diff cover clearance DoWorkXJ Modified Tech Discussion 6 August 16th, 2014 09:15
1-ton OTK steering with ruffstuff diff cover - diff cover clearance issues themangeraaad Modified Tech Discussion 40 January 14th, 2012 19:28
Front frame rail width cgmrdc OEM Tech Discussion 2 June 26th, 2008 08:03
Who has replaced a front frame rail before??? 98XJROKS Modified Tech Discussion 47 March 27th, 2008 08:02
