Old September 8th, 2017, 06:20
volumeknob volumeknob is offline
Re: Front Axle Options
So bad news guys...went to get the truck aligned last night and the right front is toed in -1.8 degrees. So now it's time to make a decision, try returning the axle to the JY it came from or deal with it. I'm sure it'll chew up tires like no tomorrow and I'd like to keep it on the road not just offroad...
Any advice? How would I go about checking an axle before buying it?
Old September 8th, 2017, 06:46
VAhasnoWAVES VAhasnoWAVES is offline
so... adjust the toe.
i cant remember what spec is, i always do the tape measure method with no issues. but toe is adjusted with your steering linkage. did you just swap the steering from one axle to another?
Old September 8th, 2017, 06:54
Wow, I must still be sleeping. I meant camber, my apologies. They fixed the toe, I had it close but they got it dialed in. I put all new Moog steering parts on it with the ZJ tie rod.
Old September 8th, 2017, 07:06
lol. that makes more sense.
whats spec for camber?
Old September 8th, 2017, 07:50
He didn't specify just said it should be as close to 0 as possible. I'm just a little hesitant to throw hundreds of dollars in offset ball joints at a JY axle. I haven't called the JY yet so we'll see what they say.
Old September 8th, 2017, 08:39
RCP Phx RCP Phx is offline
They make offset ball joints to correct any camber/caster needs!
Old September 8th, 2017, 09:50
I looked at the ones on the NAPA website and I'm glad I was sitting down lol. I'm not going to spend $100's on ball joints. That's not really fixing the issue and without knowing if the outer C is bent or if the axle tube is bent really doesn't settle well with me either. I've also read that they ware quickly and Dana never designed these axles to utilize this technology. I bought this with intentions of building it up this winter or next year. I'd rather just start with a straight axle. The JY will give me back what I paid, so that's the silver lining at this point.
Old September 8th, 2017, 10:48
Now your just dreaming! If you want a perfect axle call Currie or Dynatrac, but in the production Jeep world it's not going to happen!
Old September 8th, 2017, 11:14
Not looking for perfect but if they're all bent or damaged I'll take my chances with one at a fraction of the cost. In my opinion $300 is a lot for a used axle but with the lower miles this one had, I felt it was worth it.
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
If your camber is off 1.8 degrees there is an issue.
Seems like the alignment shop could tell if it was bent or a bad ball joint
I recomend leveling it as best you can pulling the knuckles off and putting an angle finder on the c before you pull the thing back out
Old September 8th, 2017, 11:26
I've never seen a D30 that had indentical numbers on both sides! Even my 2k(bought new) didn't from the factory!
BTW, offset BJ's have been used at the factory for years.
Also be aware of the fact that most alignment shop use specs for a factory configuration not lifted Jeeps!
Old September 8th, 2017, 12:02
I'm going to take it to a shop that actually works on lifted vehicles and get a second opinion. I'm also going to check the ball joints and make sure there's no issues there first, this axle did come from a junk yard after all. Also figured rotating the tires would be a good idea to try, they may be worn funny from the PO. I just don't trust the big chain places, this is just one of those things that I can't really dial in on my own. Again not seeking perfect, c'mon it's a Jeep lol but I think I can do better that what it is now. Funny thing is, it does 70+ with no sway or stabilizer just fine. Thanks for the pointers guys, I'll check back in next week.
Old September 8th, 2017, 12:06
Tbone289's Avatar
Tbone289 Tbone289 is offline
Tire wear will have no effect on the alignment.
Old September 8th, 2017, 12:17
^^^ That plus mine has driven perfect with about 3 different lifts for 17yrs and never seen a alignment shop!!!
Old September 8th, 2017, 12:57
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Originally Posted by Tbone289 View Post
Agreed. If you drop the shocks, track bar and steering linkage that is true. But let's not give the guy the false impression that just disconnecting the shocks will get the job done without a compressor.
That depends on what shocks, trackbar and steering you are running.
I can remove my coils by just removing the shocks and limit straps.
front axle swap options ? xj-krawler88 Modified Tech Discussion 10 April 10th, 2011 08:26
Pre-Made/Custom Front Axle Options? spinaldex Modified Tech Discussion 2 April 6th, 2009 22:22
Front axle options... rcmf5525 Modified Tech Discussion 19 January 22nd, 2008 16:22
Contemplating Front Axle Options FitchVA Modified Tech Discussion 12 June 9th, 2006 23:19
front axle options... allthingsoffroad Modified Tech Discussion 15 October 18th, 2005 07:50
