Old July 2nd, 2015, 23:07
dktool dktool is offline
Leaf Bushing Recommendation
I replaced my leafs last year and used Moog bushings, the rear ones are already DONE ! Granted it has seen a good bit of twisting in that time but I am surprised they are this sacked already.
What are good options for this bushing, or should this just be considered a "consumable" ?
Old July 3rd, 2015, 09:31
x-jay vision x-jay vision is offline
Re: Leaf Bushing Recommendation
Sounds like if you are burning through Moogs that quick you should probably just plan on doing them every year...
Old July 3rd, 2015, 09:58
md21722 md21722 is offline
I'm surprised to hear the MOOG's are trashed already. May be asking the obvious, but one thing that can kill bushings fast is if you tighten the through bolts with the vehicles tires hanging in the air; they should only be tightened when the weight of the vehicle is resting on the tires, no jack stands, no floor jacks present.
Old July 3rd, 2015, 22:25
Everything was torqued with vehicle on the ground. U-bolts, leaf & shackle bolts, etc.
Would I be better off running Poly bushings ? My shackles came with Poly's in uppers, looks to be holding up ok.
Leaf Spring Bushing.... Ghost South East Chapter 8 February 1st, 2013 22:50
Leaf Spring Bushing 4LVLFWD Modified Tech Discussion 10 August 25th, 2010 11:01
Looking for RE leaf spring bushing xjcody Sierra Chapter 2 April 11th, 2009 18:50
Leaf spring ID bushing? Red97XJ Modified Tech Discussion 3 August 28th, 2005 19:07
