Old September 16th, 2017, 20:10
WI-Jeeper's Avatar
WI-Jeeper WI-Jeeper is offline
Liberty conversion backing plate studs?
After searching all the existing Liberty disc conversion threads (or what feels like searching them all), I can't find info on where to get replacement backing plate studs / part numbers. I already pulled the hardware from the junkyard but the old studs were completely rusted out. Anyone have any info on this? Or should I just get similar sized grade 8 hardware instead? Thanks!
Old September 16th, 2017, 21:07
ehall's Avatar
ehall ehall is offline
Re: Liberty conversion backing plate studs?
You didn't say what year. This is for 2003 KJ with 8.25 rear. 6036533AA and 6036483AA are the bolt / stud (don't know the difference), and 6036556AA is the nut.
https://www.factorychryslerparts.com...6036556AA.html
my '91 beater rebuild
Old September 16th, 2017, 22:26
WI-Jeeper's Avatar
D'oh my bad, its late, weather is hot, milk was a bad choice. 2003 KJ with 8.25 corporate is exactly what I needed, thank you!
Edit: After looking at the prices for OE studs/nuts, I think grade 8 hardware will work just fine...
Old September 17th, 2017, 05:05
ehall's Avatar
On my TJ the bolt heads are cut so that they are flat on one side (instead of pointed). This allows the bolt to sit against the axle tube so you don't have to hold a wrench.
Old September 19th, 2017, 11:23
WI-Jeeper's Avatar
Yep that is one of the reasons I wanted the factory knurled bolt. However at a cost of $8 and up for each one, I'm going to opt for hardware store grade 8 fasteners instead. For that price I can hold a wrench for 5 minutes
Old September 19th, 2017, 11:53
ehall's Avatar
May not be able to seat them without cutting, interested to find out
Old September 19th, 2017, 12:03
RCP Phx RCP Phx is offline
I didn't need to do the studs on my 2k!
Old September 19th, 2017, 14:03
TRCM's Avatar
TRCM TRCM is offline
On the ones I've worked on (not so much jeep axles) the heads are shaved so the head clears the axle tube, NOT to make it easy to tighten with 1 wrench.
Old September 19th, 2017, 15:57
sinat01's Avatar
sinat01 sinat01 is offline
I ran into the same issue, studs were way rusted out. dealer had em for $12 a piece, and I usually get a bit of a discount. anyone priced em from advanced?
Old September 22nd, 2017, 12:00
WI-Jeeper's Avatar
Wow I think you win. My feeble brain was assuming I had to get new studs because I pulled them from the donor vehicle, not thinking my XJ would already have them from the existing drums. Thanks, I'm (probably) an idiot!
Yes, the stud heads are cut off on one side to clear the axle tube. If mine are bad and I end up going with the grade 8 solution, will try to post back with results. I can't in good conscience pay $8-12 each stud, that is highway robbery!
From my research, you won't find these anywhere but the dealership since they are an odd size and not a common part like a lug/axle stud. But I would be interested if anyone found out what the size is. If not, I will bust out the ol' digital calipers when I tear mine down.
Old September 22nd, 2017, 13:12
If you should find that you need new ones, check Currie!
http://www.currieenterprises.com/CE-2012
Old September 23rd, 2017, 12:49
sinat01's Avatar
BTW rock auto has studs for the KJ for like $1.40 a piece
Old September 25th, 2017, 13:45
WI-Jeeper's Avatar
Thanks for the link, that's perfect! May go that route if I don't have time to grind down some bolts myself.
Got a part number for these? Lug studs are about that price, but I'm looking for brake backing plate studs which are completely different in size.
Old September 25th, 2017, 17:06
sinat01's Avatar
Got a part number for these? Lug studs are about that price, but I'm looking for brake backing plate studs which are completely different in size.[/QUOTE]
nevermind had a dumb moment and typed before I thought. they were lugnut studs, which youd need to put D30 studs in anyways. ive seen the people use grade 8 bolts for it.
could you find a wheel stud that's the right size and cut it to the same size as the backing plate stud?
Old September 27th, 2017, 12:06
WI-Jeeper's Avatar
No worries! I'm sure I could find something, but the best two options at the moment (Currie t-bolts or grade 8's from hardware store) are the most cost-effective and least time consuming thus far.
Still scouring the interwebs for other fastener solutions from vendors like Fastenal, ARP, Grainger, etc. just out of curiosity and if I find something will post back here.
Jeep Liberty Rear Disc Backing Plates M4Madness Modified Tech Discussion 14 August 17th, 2015 11:27
Ford 8.8 Backing Plate? sureshot007 Modified Tech Discussion 21 July 25th, 2010 22:50
8.8 backing plate homebrew Wanted: Private Party Only 0 April 15th, 2010 06:21
D35 backing plate on a D44? Shorty Modified Tech Discussion 7 December 22nd, 2008 08:12
XJ D44 Backing Plate FitchVA OEM Tech Discussion 2 March 20th, 2006 07:09
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
