MahnkenVille
- Liverpool, NY
97 XJ, 4.0 AW4 190k miles. Stock except hellas, cb, 3" lift and tires.
Left my interior light on for 2 days...Jeep didn't start. I jumped it with my mom's car and drove it around. Volt meter was reading 14 when engine was on, and 2 notches under 14 when just on accessory (what it usually reads). As soon as I started it up, I noticed it was running high. Sitting in my driveway on park, engine somewhat warm, RPMs were 2500. In drive, it felt like it wanted to go and go, currently keeping around 1500-1250 (engine warm) at 35-40mph and idle. Definitely noticeable higher idle speed, and its harder to brake. I have to put the pedal to the floor to make the jeep stop moving. Any idea what's going on here?
updated symptoms from tonight: -between 10 and 0 when braking, it sort of lurches and then the RPMs shoot up a little, then go back down.
-from a stop, jeep will accelerate by itself (including upshift) even up a hill. I got to 20 before I had to slow it back down. Did NOT touch the gas pedal
-Idle in drive seems to be around 1300RPM (stopped at a light). In Park, it shoots immediately up to around 2300.
-faint smell of barbeque (literally smells like charcoal) coming from somewhere.
The ASE Master Tech in our club told me it was probably the computer resetting after the battery dying and it should go away after some running. he recommended idling it in the driveway for a few minutes. Tried this, it didn't go down.
I did search, didn't really find a lot on this but more on vacuum leaks.
