Incredible Hulk
- Burnsville, Minnesota
OK so here is the situation. I am building a tube frame for an RC truck. I have seen too many cool things about it, and I need a cheaper hobby that doesnt require a heated garage to biuld. So, I am trying to teach myself how to solder a tube frame.
I am using 3/16" steel rod and brake line and trying to learn how to butt connect them, like a T. So someone teach me how to do this. I bought a propane torch and some silver solder. I started practicing last night, but when I heated the joint teh silver would just melt and fall off. So I have been told that it is better to use brass solder since I dont have access to a MIG.
Basically, I clean it real good, add flux, heat the crap out of the joint, remove the heat, and place my solder right? But it wouldnt flow into teh joint like it does on pipes, so I am wondering if there are tips or tricks I should know. Maybe its just that I need to get brass solder. ANyone else have ideas? Thanks for the 101.
josh
josh
