37's on D44 or D60
Paul S said:
In defense of Warn's hubs (which I agree look like junk metal), your front tire was bound-up enough to stall your winch. Something had to let go.
Paul
Yes, I was in a bad weggie. I'm going to post some pics of both hubs
tomorrow. Looking at it today, the Fords look much better
Warn is on the left
David Taylor said:
Warn is on the left
Is that a broken Warn hub compared to a unbroken stock OEM Ford hub? I haven't broke yet, then again I have wheeled just under a day on the Con since my build up. :laugh3:
I run the unbreakable "clear" shafts on my D44
33's
ran them all summer, no problems
Mike L said:
So who out there has upgraded to 37"s since the last post a few months ago? Have any of you finished your projects and gotten them out on the trail yet?
How about d44, 36" IROKS+heavy foot+stock shafts=
I have installed the drivers side superior and ctm. When I went on this run, was still waiting on the long side superior.
33's
really? got any more info on those things?
Well, pretty much sounds like any one running bigger than 35's have swapped in a D44. I'm running 37" MT/R's on a stock rear D44 and the stock D30 up front! I know it's just a matter of time before I break an axle. That's why I carry 2 spares per side. I've wheeled it pretty hard and haven't broke it yet, but I still go prepared. My question is what will break first, shafts or joints? Thanks again guys. Love the site!!
Bill
Yes. Good to know your junk will be well tested before JV. I'm sure you have the bugs worked out.
I'm not going to make JV this year.
think about it
it'll come to you...
Bill
First the caps will spit out like this:
and then the splines will twist like this:
and if you escape axle breakage for a while (it's not a question of "if", it's a question of "when"), you'll for sure be bending tie rods like pretzels if you do any kind of wheeling at all. I bent at least four tierods before the upgrade to the 44 and 1 ton steering.
