Old July 8th, 2017, 13:49
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: poor idle with AC on
Maybe, if the sensor grounds are seeing back voltage from a poor ground system.
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old July 8th, 2017, 23:50
4x4JeePmaNthINg's Avatar
4x4JeePmaNthINg 4x4JeePmaNthINg is offline
i know it might have been far fetched, but i couldnt have hurt to asking while im digging for answers.
with the mileage it has i could see the IAC maybe, but i havent been able to reproduce the symptoms very well lately. ill keep putting the AC to 4 and see if i can get any more info on the behavior, i wish we could post videos clips on here, it would really make it easier sometimes.
Old July 9th, 2017, 14:11
Ecomike's Avatar
NAXJA# 2091
Just post the youtube link.
You may have a small vacuum leak, in a vacuum hose that is confusing the O2 sensor..., one that is actively leaking when you turn on the AC. Did you ever check the vacuum lines at the passenger side firewall area. get a map of their routing and check them all. Even a tiny leak can cause issues.
Top 10 causes of a bad poor rough idle.... bimmerjeeper OEM Tech Discussion 7 November 26th, 2012 12:55
Intermittent poor idle on 00' XJ xjtrailrider OEM Tech Discussion 6 May 15th, 2010 19:30
bad idle and poor running CW OEM Tech Discussion 11 May 2nd, 2007 23:11
Low RPM stumble/poor idle blaisetd OEM Tech Discussion 31 August 28th, 2006 21:16
88 4.0l low/poor idle woody OEM Tech Discussion 3 January 5th, 2004 10:16
