ParadiseXJ
- Paradise, CA 95969
So, I got a nice ZJ V8 tie rod from the yard wanting to swap my stock one in the MJ. When I installed it I measured from bolt center to bolt center and set up the new (ZJ) tie rod to the same length.
When I went to bolt it in I had to reduce the length by about an inch. What I need to know is how to adjust it back out (as I've never done this) so I can get it lined back up enough to drive it. Right now the pass side looks straight up and down, but the drivers side is angled in at the top.
