cnjcherokee
- Middletown, NJ
I say not worth it, to big and awkward. May as well just grab the correct size wrench. It is the same for the DogBone tools out, so what if it has 20 different sizes if it is to big to work anywhere.
i have a dogbone and its been stupid useful. and i have used a the handle of a 3/8 socket wrench in it to create a breaker bar i would totally recommend throwing one in your toolbox.
I have an actual breaker bar and if needed my floor jack handle slips right onto it. Why would I want to use a dogbone for a breaker bar? With the way it is set up I could see it failing under extreme pressure like that or even just the things rotating causing problems.
. Makes a decent "bang on the part in frustration" device as well.
