ren
- frenchburg, ky
You need the lock cylinder, as the ignition switch is located farther down on the column, and is actuated by a rod that is moved by the lock cylinder.
The blinker sockets can go bad(mine did and the lights quit all together). I replaced them with some that I swiped from a mid-80s' Dodge van, as these are metal, not plastic like the factory XJ. They have a bad tendency to loose ground (plastic ones). Try replacing the flasher with the one from the 4-way and see if that works better, if so, you have a bad flasher relay.
Good luck
Good luck
