My 1997 4.0/AW4 XJ wont start. It had bottom end problem so i put a good used block in it new timing chain blah blah blah... So i got it back in the jeep and now the thing wont even run. It's getting gas and spark but im not sure if the spark is hot enough. How possiable is it i screwed up the CPS while sticking the motor back in? I also forgot that the battery was still hooked up twice and grounded +pos lead and shot sparks is it possiable i screwed up the comp from that?
I'm 99% sure the timing is correct when i had the motor i checked it sevral times cause i knew it would come back to bite me in the ass if i screwed it up. The spark plug wires are also on correct i checked that about 8 times allready. and i sprayed starting fluid in the TB still nothing.
So any ideas on what to look for?
