Gonepostal
- WY
Pictures of the install would be fantastic.
Ya, at first I was dissapointed that it did not have adjustable shift stops, but, seems fine right out of the box.there won't be anything to adjust.
Sorry, done did install it already... but may pull the consol(sp?) tomorrow to attach the shift lever to the drivers side of the shift actuator (too far to the passengers side for my liking... I'm small), If I do I'll snap some shots... actually might attempt to bend the shift lever to be shaped more like the stock lever as well. Absolutely love the action/feel and slightly extended stick length, just need to get it a little closer to me.Pictures of the install would be fantastic.
That info. is invaluable!The most fun part was getting the four new bolts in. Needed a 13mm 1/4" drive socket. Don't forget to pop off the nylon "bushing" from the bottom of the stock shifter and install it on the new one.
I could build my own for all of $15. machine a spacer. take two shifters. cut the nub off the bottom of one, up next to the pivot, cut the nub off the other one, next to the ball that fits into the shift forks in the trans. weld nub on.
the part welded on would be the same length as the spacer. end result, shorter throw.
Thank you very much.DIY rebuild for the inner boot: http://xjav8r.blogspot.com/search/label/Shifter Boots
