comanche91
- Sweet Home Alabama
themud said:2 Questions for ya...
1 Could you not simply the wiring and just wire up both fans to come on together IE youd use even less fan power as they are both working together and the spal can control them both at the same time???
2 How did you plan to draw air through the 5 inches of radiator not covered by the fan shroud of the primary fan, In AZ we need every amount of cooling we can find to help keep the jeeps cool in 118* weather especially in stop and go traffic??
Otherwise looking to try this on my rig but would want to use both fans at lower speed to help keep things cool...
themud
Good questions. Answers:
1. Yes. You could simply parallel the ECU output turn-on ground signal to trigger a relay to the new fan so both fans would come on at once. Many have done it this way and you would not need a separate controller like the Spal if you did this. But the existing stat sensor for the aux fan turns on too late for me, like 217* or so depending on how calcified the tip of the sensor is. Too unreliable I figured. I also wanted redundancy since both fans would be dependant on the same sensor - not good if the sensor should fail. So I elected to use a separate sensor for the new fan and make it stand-alone w. the Spal sensor that also gave me programmable LO and HI speed outputs and leave the existing fan as-is, but did wire in a manual dash switch if the Spal controller should fail. The Spal can control an additional fan, but only in the "switch" mode, either OFF or ON, but not two fans with both having variable speeds and programmable temps. I'm not using this function.
2. Yes, you are right. The 5" of rad not covered was a compromise. I did this to provide adequate clearance for the 3-1/2' depth OEM XJ aux fan. IF I had cut off the mech. fan pulley shaft housing as on Gojeeps site, I could have fit a 15" or 16" larger fan covering more of the rad surface, because cutting is the only way to provide clearance for the larger fans, but I wanted to be able to return to the mech fan configurtion if necessary. The XJ/MJ rad is only 14" high, so above and below air would have been wasted anyhow. The Jeep XJ aux fans, especially with the later 97+ curved blade models, have an excellent CFM for their size. We get high temps too here in 'Bama, and so far so good, it's performing better than w. the mech fan.
