- Birmingham, AL
Wheeled pretty good this last weekend and after 2 days of riding I started hearing what almost sounded like a rubber mallot hitting the underside of my Jeep on every little bump. Well I get under there today and the is a hole where the sheetmetal has actually ripped off the underside of the Jeep where my right rear shock mounts. Now I did break both bolts off in the upper mount putting the lift on so I had two nuts welded onto the underside and bolted the shock mount to those, well now everything is just sitting against the underside of the Jeep.
So I have this idea. Can I weld some thin plate to patch the area and then buy a set of these Detoursusa upper shock mounts and weld them to the new metal? Anyone see a problem with this? http://www.detoursusa.com/xjstm.php
I really rather not have any more loss in travel, but I can't think of anything else that might work? Mybe weld another nut to the new metal surface and drill a hole through it to mount a bolt?
I'll try to get a pic of the damage.
