- Hammertown, USA
Ok So I can see your argument on spindle strength . we could say the 30 gets the advantage here, but it seems marginal to me for all intents and purposes due to the high cost of the kit.
its pretty well known about the Tbird caliper swap on the hp44s though to clear 15" steelies with minimal grinding (No problem clearing on mine) . They arguably pump as much fluid as dual piston fronts if not more and were stupid cheap compared to WJ brakes so you can retain 5 on 5.5. 900$ on WJ stuff or 40$ on t bird calipers and another 85$ on custom brakelines to fit them. advantage 44.
If you are going to spend 1600$ on a yukon hub kit for a d30 you can spend 1700$ for 30 spline RCV kit with 30 spline hub gears for your 44. I would say thats advantage 44.
Your numbers are totally invalid, though. Putting the two costs of upgrades side by side you are assuming someone already has fully built and bracketed 30 and 44 axles sitting in their garage, and are going to spend $900 to upgrade one or $40 to upgrade the other.
I'm not saying there isn't a right place for a front 44 (I have 44's on both XJ's), but its the 1% and not every ****ing person that asks a question about upgrading their front axle.
