The hole window just pops out, Have you seen if there is rust, If i had that same problem i would pull the whole window becasue there is probley more rust then what you can see. If you havent pulled your carpet up you might want to check because i bet you have some leaks. Got to love the cherokee
It seems as though its just the frame that is rusting. So do I just remove the trim from the inside and push the window out? Then Im guessing I can replace the frame as a whole when the window comes out??
