creekscout
- southeast Pa
I would like to know if the window can be adjusted so it runs up and down evenly front to back. Once my window is down all the way the front edge of the window is about 3/8 inch lower than the back edge. Then when you go to put it up it doesnt work very smoothly because it is running up somewhat cocked. I would like to know if the one screw with a plastic bushing in it that holds the window to the lift post , could it possibly be like an eccentric hole which would allow you to adjust the position of the window in the track. Any help will be greatly appreciated. Thanks
