Bringing up an old thread. I started on this project and pushed it to the backburner as priorities got shifted, so goes life. :looney:
Well I had the day off so I got some work done on the bumper. A few weeks ago I had a piece of .25" plate bent up to act as my crossmember reinforcement plate. Cost $20.
Here's the passengers side frame plate, the bolt pattern is similar to the C-Rok plate. BTW, I don't normally cut out holes with the torch but this plate was a piece of hardened steel from work so drilling wasn't going well.
These are the side bolt tabs. They will be drilled and tap'd for 1/2"-13 and welded to the end of the bumper mid section. The side mounting bolts will go through the frame plate, then the unibody tabs, then the crossmember reinforcement plate, then thread into these. Right now they are just tach'd in place so I can center punch the hole locations.
Here's the crossmember reinforcement plate.
And here it is mounted up (bolts are just in to hold it up for the pict). Part of the bottom will be cut off to the angles of the front crossmember of the unibody.
And here is a view from down low.
I also scribed a line on the fan shroud to make that cut but I forgot the pict. It looks like it is going to be around 2" and will leave enough material to keep the shroud together and the lower mounting tabs intact.
More later...
