Cherokee Freak
- Newfoundland, Canada
Ok folks, this is the first time i have ever asked a question on this forum so if I ask something stupid or post this somewhere where it's not suppose to be, go easy on me.
Heres the problem, I have a 92" Cherokee laredo and this is number 17 of 19 I have had and this is a first for this problem. It has 98000 on it and the transmission is having shifting problems. Usually when I start off, I can drive for about ten minutes, i'll stop for something and when I return to the Jeep to go again, it sticks in first/second gear. The first time it happened it corrected itself within the matter of a minute. The second, it took ten minutes, the fact that i hit a bump at the moment it started to shift again had anything to do with it...i don't know. The third time it happened and i immediatly clicked the shifter into 3rd and thats where it stayed. It seems to shift between second and forth but will not go into first. Transmission shop says the tanny is fine, it's an elec. problem. Please HELP!!!!!!!
P.S. Where is the Powertrain control module located?
