JJacobs
- Fort Collins CO
Glad you got it pinned down. Be careful with shims- make darn sure the leaf spring center pin has enough left past the shim to get a good bite into the axle perch locating hole. More than about a 4 degree shim and it gets sketchy. The smaller shims usually are notched at one end so you can loosen up the ubolts and slide them in. If you need a larger shim try to get the style that bolts to the leaf pack via the center pin/bolt.
