I believe MIT has a SYE conversion with shaft, I have been looking at it. And a new shaft. After my Hack and tap start to vibrate. There was way too much slop in the flange and the output shaft of the 242 for my liking. Got a new one from RE and then got my CV rebuilt, trust me on this one, just go buy a new shaft. It cost me $180 for just a ball kit and two u-joints around the CV plus labor, should have brought the vasaline on that one. Plus you can't get a geaseable centering joint for a flange style CV, not happy at this point. SO I put the shaft in and I do have some vibes from the rear axle pinion about 4 degrees too low since I put new springs in, but new shims are going in tonight. Anyways, driving to work got the pinion vibe, by now I can tell the difference between pinion and CV vibes, ask me how, but also got what sounded like a worn CV joint, kinda a low snapping noise. So while I am under the jeep tonight going to check that out. Now I am really not happy.
So, moral of the story is, if I had to do over again I would go with the MIT SYE kit, its actually shorter than the RE hack and tap and using a yoke style CV which you can get geaseable centering joints for.
Now I am going to get off my soap box and go back to work
