When leaf springs go BAD!
ChuckD
Kerman, CA
When leaf springs go BAD! :twisted:
After I put on some lift shackles I now have a 1.25" difference. The driver side leaf spring has flattened about 1.25" compared to the passenger side. It's a stock spring with 1 yr old Rough Country add-a-leaf. On a 93' XJ w/130k.
My first question is, is the entire leaf spring bad or is it just the add-a-leaf. Can I rebuild it for another couple of seasons?
My second, I have a set of 4runner springs at my disposal. They are 2.25" wide(at least that's what I remember). My add-a-leaf is only 2.25" wide. Can I use these leaves to rebuild mine?
no clue wich one is bad, I would assume its the aal
You would have to look and see, my pack contains a 3 in rusty aal and a 70s mustang leaf. the mustang leaf actually fit in pretty well.
Don't mess with the 2.25" junk. Go get yourself an S-10 pickup leaf pack from pick and pull. The main leaf is too long, but the rest work very well for about a 4 inch lift pack. Just use your main leaf and mix and match till you get to 5 or 6 leaves.
CRASH
