tantotrailers
- IL
I’m installing some upgrades and I was having some clearance issues when at the suspension limits so I did some measuring and my driver side wheelbase is off from 101.4” by about a half inch and the passenger is off by a full 1.5”! I have CavFab adjustable upper and lower short control arms and they are supposed to cover 0-6” of lift. I am on a 3.5” lift so within the range….but I just can’t see how these can have that much adjustment. From my research I need to have 1.5x the diameter of the threaded rod inside the end of the control arm, which brings me to about 1.3” threaded in, which is what the picture shows on the heim, that is pretty much where I had them set when I started…I did order some alignment shoe shims to push that forward at the lower body bracket, if the nuts turn…but that will only get me a little over a quarter inch forward.
