- West Sacramento, CA
kid4lyf said:I did.
I'm right.
I see it your way.
A 15x8 with 4" of BS (or 0 offset) puts the center of mass directly over the wheel mounting surface. Adding a 2" spacer puts the CM 2" outboard of the hub. Replacing the wheel and spacer with a 15x8 with 2" BS again puts the CM 2" outboard of the hub.
Both the spacer and the 2" BS wheel mount directly to the hub. Both have the same distance between CM and hub. Both create the same moment about the hub.
But I'm only an ME student.
