jonn
- kimberley bc canada
i was reading the thread on relocating the vacuum bottle and began wondering what does that thing do?
To bad that is the only answer some of you guys can give anymore is SEARCH, this you to be a good sight to have questions answered , must be the new breed!
Trailbst said:The one function that you will miss, if you loose a connection to the vacuum bottle, is the ability to change your blower settings. You'll be stuck with just defroster.
Erik
Actually, the defroster is not always "on" on '97-'01 models. It does receive some air regardless of the setting, as you mentioned, but it's because of the way the dash and air routing were designed--the "flap" that cuts off the vent can't close completely properly.dynamite44 said:on 97-01 (with the heater valve inside the dash, not exposed like earlier models) the defroster will be on all the time. you can't turn it off, even if you put the selector to off. the faster you go, the more heat you'll get. don't ask me why i know this
wow.... and you are soooooooooooooooo helpful yourself :dunce: Suggesting search is not a bad idea: it's entirely possible that the seeker The Answer to Life, the Universe, and Everything was not aware that after hitting that litting search button he might have found out that the vacuum bottle holds vacuum for all the doohickeys that require vacuum to operate.exjay33 said:To bad that is the only answer some of you guys can give anymore is SEARCH, this you to be a good sight to have questions answered , must be the new breed!
