Cherokeekid88
- North Carolina
So im sure some of you remember my numerous posts about my oil leak, well me and a buddy tracked it down 2 weeks ago and replaced the the o rings on the oil filter adapter. It was bone dry for 2 days straight. Then there were some spots underneath the jeep. So we checked it out again and it was coming from the same spot, so this time i got the O rings from the dealership instead of napa, and got em installed last night and test drove it before i took it home and everything was good, so i parked it last night and this morning i found yet another spot of oil under my jeep. So i get underneath and check the oil filter adapter and they is a little oil around that area, but not enough to be a big deal, so im guessing its just leftover from taking it off and stuff. Well then i look at the 2 lines that follow along the passenger sde of the oil pan (Im guessing tranny lines or something) and there is a drip of oil on the elbow bend of it where it almost meets up with the bellhousing. So im lost here, Im SO SICK of dealing with leaking oil. The RMS is not leaking, the VC is not leaking, The Oil Pressure sending unit is not leaking, and i just did the O rings 2 times. Now the only thing left is the oil pan gasket, but i dont see any signs of it leaking and how the hell oil would get on the 2 lines and run down?
ANY HELP???
ANY HELP???
